Closed Thread
Old 09-05-2016, 09:59 PM   #4276
TwoFiftyShifter
Re: What did you do to your truck today? Chapter II
Originally Posted by Possmguts View Post
Dang.. what is that bed? Like 20 feet?
Cmon man it's a long bed... 8 feet. Can fit two motorcycles in and close the gate.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline
Old 09-05-2016, 10:13 PM   #4277
74baggedbug
Buddy made these for me to take the place of the factory c/10 on the fenders
74baggedbug is offline
Old 09-06-2016, 04:59 AM   #4278
kilrcady
My first truck was a 6' bed. I like the look but never again if I want to use it. 8' fits a sheet of plywood and yes, clise the gate with a bike in it
kilrcady is offline
Old 09-06-2016, 08:51 AM   #4279
1968aj
I like those emblems. does your buddy have plans for selling any?
1968aj is offline
Old 09-06-2016, 09:41 AM   #4280
flashed
Those look great .
flashed is offline
Old 09-06-2016, 10:33 AM   #4281
VWNate1
VWNate1's Avatar
Smile Re: What did you do to your truck today? Chapter II
Those TEXAS C/10 fender callouts are sweet .
My '69 C/10 came from TEXAS but I don't think I'd use them....
Maybe ? .
They look so sharp .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-06-2016, 11:09 AM   #4282
74baggedbug
Not sure but I'll ask him
Old 09-06-2016, 09:37 PM   #4283
blf
Replaced my power brake booster and master cylinder. Both from NAPA. Booster was a rebuild and the MC is a new one.
The brakes have been mushy since day 1 and bleeding them has been on my todo list. I discovered it was leaking from where the MC meets the booster so I replaced both since it had eaten up the paint on the booster. The booster was pretty nasty in the back so I'm glad I did.
I bench bled the MC. I will jack up the truck and flush/bleed each corner tomorrow.
I did discover than neither clevis pin had any kind of retention device (the one under the dash that connects the pedal to the pushrod, and the one inside the bracket between the booster and firewall. There's no hole so is it supposed to be a circlip? It's a little scary to have them missing.
blf is offline
Old 09-06-2016, 10:49 PM   #4284
In The Ten Ring
I checked the mail, which held some new-to-me parts. I also bought more from the site.
In The Ten Ring is offline
Old 09-07-2016, 10:28 AM   #4285
VWNate1
VWNate1's Avatar
Post Brake SAFETY
Yes , a little folded over sheet metal clip, you can use an 'E' clip if you prefer .
Both types of clip are sold in the " HELP " aisle of your FLAPS .
-Nate
Geezer
VWNate1 is offline
Old 09-07-2016, 10:32 AM   #4286
blf
Re: Brake SAFETY
The 'E' clip is what I was thinking of. I will probably run out to find one or the other at lunch. Thanks for the tip!
blf is offline
Old 09-07-2016, 10:38 AM   #4287
toolboxchev
I order parts today. I did that yesterday, I will be doing that tomorrow!
toolboxchev is offline
Old 09-07-2016, 04:50 PM   #4288
RodnRudy
RodnRudy's Avatar
Spent the weekend digging out hedge stumps from around the house so today I and the wife took the 68 to the nursery and loaded up new bushes to plant.
She's now officially a "work" truck!
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 09-07-2016, 06:59 PM   #4289
rsgt
rsgt's Avatar
I installed some aluminum gutter screen to the cowl piece. I used construction adhesive.
rsgt is offline
Old 09-07-2016, 07:29 PM   #4290
rustytruck50
rustytruck50's Avatar
Got my plates on....think I broke a sweat in my screwdriver hand! LOL
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 09-07-2016, 08:23 PM   #4291
firedemon
I like the looks of that better than the one lmc sells . the one lmc sells works in that it keeps everything out , but I think the holes are too small seems like the vents don't throw enough air now
firedemon is offline
Old 09-07-2016, 08:35 PM   #4292
Metaldoc
Metaldoc's Avatar
I just did this and looks better with screen in to cover the wiper arms.
Metaldoc is offline
Old 09-07-2016, 09:03 PM   #4293
kilrcady
Interesting,I'm new to this vehicle.Is this how the floor vents fill with leaves?lol
kilrcady is offline
Old 09-07-2016, 09:18 PM   #4294
firedemon
exactly
Old 09-08-2016, 09:18 AM   #4295
blf
So I flushed the brakes last night. The brake fluid looked terrible. I got new clear fluid at all 4 bleeders now.
In back I took the drums off for a look, one side is mucked up with 'grease' -- looks like I have an axle seal issue, and looks like it's been there for a while.
In reading about the repair I also realized my truck must've been converted to 5-lug. I'm curious how it was done (whole new rear end or 5-lug axles). I need to see if I can find some numbers on the rear end to see what's involved in the repair for real. I'm not sure I want to tackle it. I do want to overhaul the rear brakes but now I'm wondering if I put the money into discs instead... one thing leads to another.
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection
blf is offline
Old 09-08-2016, 09:46 AM   #4296
blf
Here's what I saw inside the drum:
blf is offline
Old 09-08-2016, 10:52 AM   #4297
1968aj
I think if you had a seal leaking it would be more concentrated around the axle
1968aj is offline
Old 09-08-2016, 11:08 AM   #4298
blf
Hmm -- it smelled sulfurous in there, like gear oil. What are the other explanations? I know the brakes need work back there so it could be a leaky wheel cylinder but it sure seems more like grease or gear oil. My theory is it's leaking down and getting churned up by the brakes. (The shoes and drum were all greasy)
blf is offline
Old 09-08-2016, 03:00 PM   #4299
crazyjeenyus
crazyjeenyus's Avatar
Originally Posted by SoCoC10 View Post
Installed some CPP lowering springs. Here is the after...
Nice truck, is it a stock GM color? What is the color name/code?
'67 c10
'65 c10
crazyjeenyus is offline
Old 09-08-2016, 03:15 PM   #4300
Dad's72
Dad's72's Avatar
Good looking truck. What is the drop on your truck?
Dad's72 is offline
Closed Thread
