Old 09-07-2016, 05:44 PM   #1
Crappie Hog
Crappie Hog's Avatar
Not sure of the Year
This one belongs to one of my Crappie Fishing Club members. He told me that he would take best offer for it. You wont find it For Sale anywhere. If someone was serious about it I would put you in touch with him.
He has already restored one older car and one truck. Told me he had already made his mind up. And wasn't going to do another and would take best offer for this one.
Crappie Hog is offline   Reply With Quote
Old 09-07-2016, 05:46 PM   #2
Crappie Hog
Re: Not sure of the Year
Couple more pictures
Old 09-07-2016, 06:10 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Looks like a 63 from the side emblem.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-07-2016, 06:14 PM   #4
bpmcgee
bpmcgee's Avatar
I don't believe it's a '63 - those had dog-leg doors still I believe. Must be 64-66
bpmcgee is offline   Reply With Quote
Old 09-07-2016, 06:20 PM   #5
63burban
Chevy addict
1964
63burban is offline   Reply With Quote
Old 09-07-2016, 06:57 PM   #6
62stepside longbox
62stepside longbox's Avatar
That emblem with the straight pillars, definitely a 64 if its original
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 09-07-2016, 07:15 PM   #7
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
It has backup lights, If those are original it is a 1966.
66Gilbert is offline   Reply With Quote
Old 09-07-2016, 07:16 PM   #8
62stepside longbox
Backup lights came installed on all 66's but were a dealer add on in earlier years, I've even seen a 60 with backup lights
Old 09-07-2016, 07:26 PM   #9
66Gilbert
66Gilbert's Avatar
The only way to know for sure would be to post the vin# if it is original to the truck and the cab or vin tag have not been changed.
Old 09-07-2016, 07:27 PM   #10
jtrichard
64 for sure.... Unless the front fenders and/or badges have been changed .... I would say they have NOT been
jtrichard is offline   Reply With Quote
Old 09-07-2016, 08:00 PM   #11
NevEno
NevEno's Avatar
Rearend is not 64. One way to tell if the cab is a 64 is by the lower inner fender mounts on the cab.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 09-07-2016, 09:56 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I first read it as:
"one of my crappy fishing club members"
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-07-2016, 10:45 PM   #13
62stepside longbox
I'm just about positive it's a 64, get a picture of the vin plate and we can tell you, it will be in the door jam
Old 09-07-2016, 11:02 PM   #14
Classic v6 GMC's
Classic v6 GMC's's Avatar
NevEno is right about the rear end.
Should be a 66 being it a has a silver gauge cluster bezel.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 09-08-2016, 12:26 AM   #15
TJ's Chevy
TJ's Chevy's Avatar
Even easier way to tell if it's a 66 is the tag on the driver's side kick panel that displays the engine options.
64-65 had the 153 4 cylinder, two 230 6 cylinders, 292 6 cylinder, and and 283 V8.
66 had the 194, 250, 292, 283, 327 on the tag.
Old 09-08-2016, 01:09 AM   #16
'63GENIII
'63GENIII's Avatar
Originally Posted by LostMy65 View Post
I first read it as:
Me too. Thought this thread was gonna take a bit of a weird turn. Sorry I can't help. Its not a knee knocker cab so '64 + is my vote.
I do have a couple of crappy friends but none of them fish... probably what makes 'em crappy!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-08-2016, 01:48 AM   #17
Slow Build
Slow Build's Avatar
The frame is 65 or66.
The cab is 64, 65 or 66.
The side emblems are 63.
You might want to check the VIN on both the frame and the cab to see if they match.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-08-2016, 02:44 AM   #18
jtrichard
I stand corrected I was thinking the bow-tie was on the bottom of 64 badging but I had it bassackwards 63 is on the bottom ... So looks like front fenders have been changed
Old 09-08-2016, 10:04 AM   #19
1963c-10
1963c-10's Avatar
Whats the VIN # on the cab and frame....easiest way to tell.
Does have 63 emblems, but cab is 64-66.
1964 Short bed trailer
Old 09-08-2016, 01:33 PM   #20
Crappie Hog
I first read it as:
LOL LostMy65 I may call him that sometimes but hes far from crappy at setting a hook.
Also guys I was looking for a way to edit my post so that I could include that he lives In South Haven Mississippi. And I myself live in Memphis TN most of the time but was born and raised in KCMO.
Old 09-08-2016, 01:36 PM   #21
jbgroby
jbgroby's Avatar
Crappie Fishing Club - Ya'll don't catch much
jbgroby is offline   Reply With Quote
Old 09-08-2016, 03:34 PM   #22
ck5566
I'd give him $500.00 but would need to know the year
ck5566 is offline   Reply With Quote
Old 09-08-2016, 03:35 PM   #23
duallyjams
duallyjams's Avatar
Windshield washer were standard on 66 as were back up lights both were option in all the earlier year.
A lot has been changed on this truck, engine, trans, radiator, steering wheel, outside mirrors just to name the most obvious.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-08-2016, 04:19 PM   #24
Shaun64swb
Shaun64swb's Avatar
big back window shortbed v8 automatic i think will fetch much much more than 500
Shaun64swb is offline   Reply With Quote
Old 09-08-2016, 04:50 PM   #25
ck5566
NOT when all the other stuff that doesn't belong on it is there. Believe me I know, my 68 C10 is an example of that just getting it back too as close to Stock is quite a Money Pit
