Old 09-10-2016, 12:10 AM   #1
KyleSeal
KyleSeal's Avatar
Reinstalling Rear Pinion Gear.. How to..?
Doing a quick cleaning and painting of my rear end housing, new axle bearings and seals but keeping the same bearings on my ring gear and pinion.
Same nut and washer, how do I put the pinion back in properly? What torque? What spinning torque?
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 09-10-2016, 12:26 AM   #2
kwmech
Re: Reinstalling Rear Pinion Gear.. How to..?
Which rear axle
Old 09-10-2016, 12:40 AM   #3
KyleSeal
KyleSeal's Avatar
Originally Posted by kwmech View Post
Which rear axle
Sorry I meant to add that but forgot. 70 C10 stock GM 12 bolt NOT POSI. This is just a plane Jane rear.
Old 09-10-2016, 07:30 AM   #4
Jrainman
Jrainman's Avatar
I personaly would opt for a new crush sleeve , pinion Nut and bearings , I would think with using your old crush sleeve it would be almost impossable to set the correct Pre load on the bearing ......if you go to tight premature bearing wear will occur quickly ,If to loose same will occur at a slower pace .You will Know quickly as soon as you drive you while Here a Whine or drone noise
Jrainman is offline   Reply With Quote
Old 09-10-2016, 05:11 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
You need to replace the crush sleeve and pinion nut at the very least. They are designed for one-time use.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
differential, pinion, rear end, torque
