Old 09-10-2016, 03:23 PM   #676
JRANGER
JRANGER's Avatar
Re: 1967 Mustang Coupe Build (Electra)
dont seem to find much for 67 via caster kit
lots if sanding and fille on console
JRANGER is offline   Reply With Quote
Old 09-12-2016, 07:46 AM   #677
JRANGER
JRANGER's Avatar
more
Old 09-26-2016, 08:28 AM   #678
JRANGER
JRANGER's Avatar
Pretty much done
Old 09-26-2016, 06:30 PM   #679
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work on the console!
Ryan
1969 Chevy milk truck
Old 10-11-2016, 08:25 AM   #680
JRANGER
JRANGER's Avatar
Website stopped letting me upload via my phone so im a little behind.
Finished the console and got it wired and installed with my $200 chinese dbl din GPS unit.
Drove her 140 miles one weekend and she did great. However the next week the rear apparently opened up and started seaping more. Plus she started idling bad and when i took off in 2nd gear a foul smell arouse so i think i was burning my clutch up so ill have to be a little better about that.
So i tore the rear end a part and am waiting on seals/gaskets since the auto parts store didnt have them. In the mean time i put some rustoleum on the Chunk i had waiting to install. So ill be going from the 280 to 325 so a lil more pep and still should be able to get her on the hwy
Old 10-11-2016, 08:58 AM   #681
JRANGER
JRANGER's Avatar
I also installed a powermaster 1 wire 100 amp alt that fixed the electrical dimming issues during idle
Old 10-11-2016, 03:46 PM   #682
Dieselwrencher
Nice work! Is your rear an 8"?
Ryan
Old 10-11-2016, 03:48 PM   #683
JRANGER
JRANGER's Avatar
Yes sir! Car was originally an i6 but at some point the swapped stuff out. I was surprised how easy it was to pull the axles out. I used the Drum as a slide hammer on the lugs and it took one pull on each side..Bearings are even in great shape...I was soo shocked
Old 10-16-2016, 05:46 PM   #684
JRANGER
JRANGER's Avatar
installed the 3.25 rear chunk and torqued to 30lbs. Pushed the axles in a made sure everything fit right and turned.
I was going to put the whole rear back together but i decided the drums were old and rusty and needed replaced so since i had everything taken a part i ordered a rear disc conversion for toms classics. 11 discs and was rather cheap. So ill install those when they get here and continue to reassemble the rear.
also installed a new shifter and the boot
Old 10-26-2016, 09:06 AM   #685
JRANGER
JRANGER's Avatar
My kit arrived and i have got it installed. Took some work as the rotors had to be drilled to go over the bottom lip on the studs. Guess thats what happens when you have a hodge podge of parts. Kit uses 79 Firebird rotors and 85 eldarado calipers/pads but for $250 i cant complain
Old 12-19-2016, 09:31 AM   #686
JRANGER
JRANGER's Avatar
With the 67 running and driving i went out a bought another project...
65 coupe to convert to Fastback
Old 10-29-2022, 09:51 AM   #687
JRANGER
JRANGER's Avatar
Been a min since i checked in here.....all the previous projects have been sold....and this year i started a youtube channel for my builds...
Would love yall to check it out and subscrube:
https://www.youtube.com/c/id10tgarage
Currently Building:
69 Mustang Fastback
71 Torino GT Fastback
53 F250 Frame Swapped
