09-11-2016, 03:28 PM | #26 |
Old member
Re: Radiator Overflow Container
I ordered this one off e bay!
The caps I run. The first one they messed up so they sent another one free. Told me to keep the other one so one on the C10 and one on the 64 Impala!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-11-2016, 03:49 PM | #27 |
I have a billet bottle bolted to the side of the radiator and the hose connects from the bottom. Has been there over eight years
Posted via Mobile Device |
09-11-2016, 10:06 PM | #28 |
I am kinda lost. I thought a one gasket type cap with the overflow hose going to bottom of a vented container would work.
Coolant gets hot and expands building up pressure - pressure forces excess coolant passed spring in cap - going into bottom of vented container. Coolant cools off forming vacuum in radiator - vacuum 'sucks' coolant from vented container back into radiator. This wont work? |
09-11-2016, 10:16 PM | #29 | |
09-11-2016, 10:19 PM | #30 |
I haven't found a coolant reservoir that suits me yet, so I just used the wiper reservoir.
I have the billet coolers on my 55, on the power steering, transmission and radiator.
09-12-2016, 01:22 PM | #31 |
Here is the how the tank I gave part numbers for earlier look. Its a factory looking setup, and it was from 80s F-bodies I believe.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-12-2016, 09:38 PM | #32 |
I got it on ebay. I think it was a 10 inch. Came with brackets that I mounted to core support. ran over flow tube underneath radiator.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
