09-13-2016, 12:57 PM | #1 |
Cheap Tail Light Upgrade
I have 4 Cavaliers (95-04) at my house & it was half a year ago I was thinking about putting the lights from them into my truck & came up with this.
Maybe you to are tired of the stock light issues but all I did was chop off the old connector to make it flat. Align the housing with the back & template it (trace the housing). Cut out with a dremel tool & put the mother in there. Then make the area in the bed alittle bigger. Also included is the wiring colours for the Cavalier lights. I originally lined it up straight up & down & then grinded it down. It's alot easier with the dremel & grind smooth. I did the next one at a 90* CCW so when I twist it in it'll align facing down. (Oops on the first, you can see it) I wouldn't doubt you can do this with other light fixtures, just saying. Thank you for reading & have a great weekend. |
09-13-2016, 11:28 PM | #2 |
Re: Cheap Tail Light Upgrade
Good idea,thanks for sharing. Will any Cavalier 95-04 work for parts, or what specific years?
09-14-2016, 06:28 AM | #3 |
Old member
I don't mean this in a bad way but what is the benefit of this other than the quick disconnect?
The stock housing is also a quick disconnect and the bulbs are both 12 volts so what sir am I missing here. I can see it if you housing is missing the socket for the stock bulb.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-14-2016, 07:35 AM | #4 |
09-14-2016, 08:01 AM | #5 |
I like the idea of it, get rid of the out dated problem prone twist bulb socket and replace it with push in socket. I'll be trying this with mine probably.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
09-14-2016, 10:22 AM | #6 |
But I like my twisty bulbs! Ha. Nice job on the upgrade, always fun to make something work. Recommend if you do things like this that you create a running mod list in case you ever sell your truck or the next owner will pull his hair out trying to find what bulb to install.
