Old 09-13-2016, 08:07 PM   #1
Shibbershabber
Aftermarket interior stuff...
I just picked up a very nice 86 C30 and am used to things like... cup holders and auxillary lights...
I cant stick one of those cheap plastic consoles on the floor since the shifter will smash my cups... I dont want to put holes in the dash or anything either...
Thoughts?
Second, Id like to put some lights on, etc... but again I dont want to put holes in anything to mount the switches.....
What have you done or seen done to make the interior more functional without drilling holes?
Do I just have to suck it up?
Ahhh, another thought
Do interiors of other years bolt in?
Could I get a pair of buckets and a center console out of a '93+up and install it?
Shibbershabber is offline   Reply With Quote
Old 09-13-2016, 08:34 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: Aftermarket interior stuff...
I've seen some seat mounted center counsels before but not sure On my way! what there called. I may be able to replace existing lights with newer bulbs or upgrading to led's. Not sure on the interior.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 09-13-2016, 09:05 PM   #3
Jaysonb
Jaysonb's Avatar
Like mentioned above, a nice bench seat console, you can hook up some under dash led lights, then just wire them to the dome light/headlight switch. I think you can also get a double cup holder that slides into the ash tray.
Jaysonb is offline   Reply With Quote
Old 09-13-2016, 10:59 PM   #4
Shibbershabber
On the lights, I was thinking more of having exterior lights with switch mounted inside.
Usually there is a 3/8" hole that needs to be drilled, or something similar that secures the switch to the dash.
1986 C30 3+3 454 w/3spd
Old 09-14-2016, 04:13 AM   #5
andrewmp6
You could mount a swing out cup holder like this http://www.williamsstreetrods.com/in...rod/prd456.htm almost anywhere or http://www.watsons-streetworks.com/s...upholder-43053
Old 09-14-2016, 04:15 AM   #6
andrewmp6
Or fully custom stuff http://www.tmiproducts.com/trucks/chevy/1973-87.html
Old 09-14-2016, 09:40 AM   #7
tucsonjwt
I have a short seat top console I use in my 83. I have a granny 4 speed and the shifter gets in the way of anything longer. It does the job OK, but I will eventually install Chrysler Sebring convertible bucket seats I have and build a new console to go between the seats. I like the integral seat belts.
tucsonjwt is offline   Reply With Quote
Old 09-14-2016, 10:35 AM   #8
TKCR
TKCR's Avatar
This is what I have for cupholders. And it doubles as a armrest. It has storage for small items inside. I have the Drinkster. They have 3 types for the bench seat and a big selection on colors. With mine I had left over charcoal vinyl for my reupholstery, they were able to make mine with my vinyl. Perfect match!!
http://classicconsoles.com/bench-seat/
Old 09-14-2016, 11:28 AM   #9
SCOTI
SCOTI's Avatar
^^That^^
Then add a switch panel inside of it for added accessories & use a bulkhead disconnect. Run the wiring under the carpet & seat up through where the openings are for the seatbelt stanchions to go through. If you need to removed the console/seat for whatever reason, simply disconnect the bulkhead.
Clean & no holes on the original stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-14-2016, 01:47 PM   #10
Pano
They also make one that slides into the ashtray
https://www.google.com/search?q=asht...pZcIgP93UkM%3A
Pano is offline   Reply With Quote
