Old 09-14-2016, 10:41 AM   #1
74CustomK20
74CustomK20's Avatar
Question 14 bolt help
I'm redoing my suspension on my 14 bolt and have to get new spring plates for the rear. It is a dually axle so it takes the plates on the bottom. Anyone know if anyone remakes these? I had a set to go on top but can't use less than a 3" block to clear and don't want to lift it. Tube diameter is 3-3/8" if I remember right...
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 09-14-2016, 11:24 AM   #2
jwilson645
Re: 14 bolt help
Lots of places. Most anywhere that carries off road fab parts should have them. Here are some from Ruff Stuff. http://www.ruffstuffspecialties.com/...UB-PLATES.html
You might also try Barnes 4wd. http://www.barnes4wd.com/U-Bolts-U-B...ates_c_37.html
jwilson645 is offline   Reply With Quote
Old 09-14-2016, 03:30 PM   #3
74CustomK20
Re: 14 bolt help
Afraid those song have it. If I had a SRW THEY WOuld work. Let me try and find a picture.
Big Nate
Old 09-14-2016, 10:27 PM   #4
cheepin
Re: 14 bolt help
You may have to buy a flip kit. http://www.offroaddesign.com/catalog/uboltreversal.htm
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 09-14-2016, 11:57 PM   #5
TecRsq
TecRsq's Avatar
Re: 14 bolt help
Stengal Bros. Inc.
1105 Sumner Ave.
Whitehall PA
18052
610- 433-3149
U Bolts PN # 361-413 x 2 sets
Square bend 5/8 × 2.56 x 12.6 grade 8
23 bucks a pair x 2
Bottom plate PN # M1023 x 2 plates
17.95 per plate x 2 plates
They come with washers and nuts
I just purchased these exact ones for my 1986 K30 3+3 Dually " Cab and Chassis 14 Bolt "
FYI - I purchased the ubolt flip kit from ORD and the plates were too wide to fit my C&C 14 Bolt rear " they hit the brake backing plate ", thus my sourcing stock replacements from Stengal Bros.
TecRsq
_____________
1986 Chevy K30 3+3, 454, SM465, NP205, D60 , 14 Bolt, CM Industries SS Flatbed, ORD 6" suspension, 9.00 x 16 Michelin XML'S
TecRsq is offline   Reply With Quote
Old 09-15-2016, 11:29 AM   #6
74CustomK20
Re: 14 bolt help
Tecrsq thank you. Since you redone your rear end, how did you do your brakes on the rear? My leaf springs are above my bleeder screws.
Big Nate
Old 09-15-2016, 05:47 PM   #7
TecRsq
TecRsq's Avatar
Re: 14 bolt help
My truck was purchased from a Fire Dept and only had 34,000 miles on it, as a FD vehicle it had regular maintenance. The rear brakes were fine upon inspection and I haven't done anything to them as it all looked freshly replaced.
Also I'm looking at the Ruff Stuff brackets and a rear disk application for my truck, to replace the drum setup.
TecRsq
_____________
Old 09-16-2016, 10:42 AM   #8
74CustomK20
Re: 14 bolt help
I want to do rear disks but is too expensive atm and my drums and shoes are in alright enough shape still. When they need replacing I will probably go disks... I'll figure something out.
Big Nate
14 bolt, axle help, spring plate
