09-14-2016, 10:04 PM | #1 |
49 GMC on s10 frame th4OO help
Building a 49 on s10 frame with a pretty radical 383 stroker. I have a th400 lined up for 150 bucks but its the long shaft not the short. Anyone know if it will work?
09-15-2016, 01:05 AM | #2 |
Re: 49 GMC on s10 frame th4OO help
hmmm....might be a better question for the engine/drivetrain section. Good luck w/your search.
But then again i'm sure someone might be able to answer your question. Last edited by iowaboynca; 09-15-2016 at 01:15 AM. |
09-15-2016, 11:51 AM | #3 |
long tailshaft? not sure it matters long or short, only should matter to driveshaft length really. since you are moving the engine back you will need to make a trans crossmember anyway, and make a driveshaft anyway.
thats just my cruddy opinion based on my limited understanding of the long vs short tailshafts, which is a big deal to use in a chevelle but not such a big deal in a truck you are making new engine and trans mounts and driveshaft. and I will say it in pittsburghese: get dahn nere an nat and yinz can use the tranny, I's stunned!
09-15-2016, 02:41 PM | #4 | |
09-15-2016, 03:20 PM | #5 |
yep you should be golden! I grew up in the north hills, go stillers!
09-15-2016, 04:41 PM | #6 |
Since you will have to build a driveshaft anyhow the longer tail shaft is just that = longer.
If you were hardcore on having a short tail shaft you could pull the guts out of the trans, swap tail shafts and extension housings and go again. It may not be worth the effort and cost though.
