Old 09-15-2016, 06:20 PM   #976
Re: Project two tone.
Very nice TJ!
Old 09-15-2016, 09:15 PM   #977
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by clemdaddy View Post
great job partner… I know you got the skill for this but more important, you got the drive and energy to get it done. Stay at it… looking good.
Very nice TJ!
Thanks guyz! Slow process, but it's coming along. Hope to get some good time in this weekend. Later all!
Old 09-17-2016, 09:06 PM   #978
TJ's Chevy
TJ's Chevy's Avatar
In the middle of painting fuel lines. Just need a dern tank now! Will update with more photos when the lines are routed.
Old 09-17-2016, 11:05 PM   #979
TJ's Chevy
TJ's Chevy's Avatar
Alright! Got one of the lines mounted up. The 2nd line is taking forever to dry....anyhow, pictures! Will get some better tomorrow when it's brighter out. I have always wanted to run the fuel line behind the motor and Finally got to do it. Makes things look much cleaner up front. Painted the line the same color as the motor to help blend it in as the idea is to keep it somewhat hidden. But I like it being accessible if needed and it will be this way. Didn't come out as good as I hoped, but not to bad either for being a newb to bending fuel lines! haha! Will mount the other line tomorrow and get some pics. Hoping to get some cab work done. Later guys!
Old 09-26-2016, 03:52 PM   #980
TJ's Chevy
TJ's Chevy's Avatar
Hey guys, got some cover priming done on the cab this weekend. Made good progress for only having about an hour of time allotted. haha Have this weekend off some so serious time is in the air. If all goes right the bottom of the cab should be fully primed and paint should be on it's way pending I get the 478 v6 or not. We'll see! Later guyz!
Old 09-26-2016, 03:57 PM   #981
The1960APE
The1960APE's Avatar
Looking good, for a moment I thought you got angry at some parts when I saw the chainsaw in the picture!!!! LOL
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 09-26-2016, 04:27 PM   #982
dwcardfan
dwcardfan's Avatar
Looking good TJ!!!
dwcardfan is offline   Reply With Quote
Old 09-26-2016, 06:12 PM   #983
Ta2Don
Ta2Don's Avatar
Looking good Brotha!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 09-26-2016, 09:15 PM   #984
TJ's Chevy
TJ's Chevy's Avatar
HAHA!!!!
Originally Posted by dwcardfan View Post
Looking good TJ!!!
Thanks for checkin in man!
Thanks brotha! Hope to get some time this weekend!
Old 10-02-2016, 12:13 AM   #985
TJ's Chevy
TJ's Chevy's Avatar
Hey guyz!!!! Well today was one heck of a great day with two tone. Really happy I put that tent up so I could work in the rain. haha Had a few hours of rain today, but that didn't stop me from truck time.
Due to stupid fire laws I am not allowed to sand or grind on metal in between the hours of 10AM and 8 PM. So this morning I sanded and sand blasted until 10, then laid some more fiber fill and body filler on the already hardened fill and waited all day so that would set and harden. While waiting I got to work on fixing the clearance issues with the sway bar(not sure if I mentioned that already???) and made some nice spacer blocks. Pics of those Sunday.
I'm pretty sure I never mentioned the fiber fill...well here I am admitting. haha None of the rot on this cab was that Bad, so I figured fiber fill would do the job. Stuff dries hard as a rock and I think will last many years...especially with the 2 coats of rust tough....4 coats of epoxy...and 4 more coats of paint...I think we'll be ok. haha Oh not to mention the body filler on top of the fill. I took some giveaway pictures so you folks would see the areas I purposely left super thick for extra protection as these are prone for rot areas. Granted the truck will never be driven in rain or snow, but none the less....I don't take chances...plus side is...once the cab is on you won't see it anyhow so I could care less. haha Anyhow, enjoy the pics folks! Later! Will be laying epoxy Sunday morning.
Old 10-02-2016, 12:15 AM   #986
TJ's Chevy
TJ's Chevy's Avatar
Two more:
Old 10-12-2016, 11:46 AM   #987
TJ's Chevy
TJ's Chevy's Avatar
Well no updates quite picture worthy. Last weekend I got the bottom of the cab sealed off in Epoxy primer. Had to small a fluid tip in the hvlp so it was rather a fight trying to get the primer to spray somewhat decent, but this stuff somehow has a self-leveling additive. haha Once dry it was pretty smooth, little color sanding and it would be perfect. I also got the inside of the roof in primer after a good 3 hours of sanding to get that metal super smooth. This time with a larger tip I was still fighting the gun, but it came out almost perfect for epoxy so I am happy. Plus 2k urethane filler primer will be put on top of that so I will worry about color sanding then.
Today more parts from Summit Racing should be here.
And tomorrow my black single stage paint should be here so I can lay some paint this weekend as I have the the weekend off. Later guyz.
Old 10-17-2016, 02:10 PM   #988
TJ's Chevy
TJ's Chevy's Avatar
New air cleaner and fuel pump in.
Attempted to paint between the fins yesterday, but I did't think to roughen the surfaces a little for the paint to stick better so when I peeled tape the paint came with it...so a little rubbing alcohol to remove the paint and we'll try it again. Also didn't get the tape lines quite right either. May have to brush this.
Old 10-17-2016, 02:21 PM   #989
dwcardfan
dwcardfan's Avatar
I hate it when the paint peels off with the tape. Keep the updates coming.
Old 10-17-2016, 04:42 PM   #990
siggyfreud
siggyfreud's Avatar
Looks good! I always found painting fins with a brush was quicker in the long-run than masking/spraying. Just have to get the paint thing enough to self-level so as not to leave brush strokes.
siggyfreud is offline   Reply With Quote
Old 10-17-2016, 09:02 PM   #991
TJ's Chevy
TJ's Chevy's Avatar
It was heart breaking. haha Spent almost an hour taping it up. First coat laid on nicely and after more coats kept going on the tape popped open along the fins, let it sit for awhile and started peeling tape...and some paint came with it....at that point it was start all over again. haha So this time I will roughen up between the fins a bit for better adhesion.
Thanks! I may do a brush this time. haha
Old 11-13-2016, 12:45 AM   #992
TJ's Chevy
TJ's Chevy's Avatar
Hi guyz!!!!
Well I am happy to finally post a picture of the bottom of the cab being Done.
Paint still didn't spray to well, but oh well. For the bottom it looks good enough and I am glad it's done with. haha
Also brought the chassis out of the shop for a bit. Later folks !
Old 11-13-2016, 08:24 AM   #993
clemdaddy
clemdaddy's Avatar
the chassis looks great and I bet that six will rock and roll. also very nice work on the cab...
clemdaddy is offline   Reply With Quote
Old 11-13-2016, 10:58 AM   #994
TJ's Chevy
TJ's Chevy's Avatar
Thanks Clem! I'm excited to finally hear that thing run. Looking at Spring this coming year for the 1st start up.
Old 11-13-2016, 11:16 AM   #995
62 Barnfind
62 Barnfind's Avatar
Your chassis looks great! I can't wait so see it all together and done.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-13-2016, 01:09 PM   #996
Bomp
Bomp's Avatar
Lookin' sharp.
Bomp is offline   Reply With Quote
Old 11-13-2016, 02:09 PM   #997
Ta2Don
Ta2Don's Avatar
Progress
DON
Proverbs 27:17
Old 11-13-2016, 09:50 PM   #998
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Bomp View Post
Lookin' sharp.
Progress
Thanks guyz!!!
Pending on how the weather(and paycheck) is, should be getting some paint for the under dash and working on getting that knocked out this weekend. Once that is done the cab can sit on the rolling cart like it's supposed to and I will start prepping the inside floor panel for primer and paint. All weather pending at this point. Parts will be on order soon. Hope your weekend was a good one gents.
Old 11-13-2016, 11:16 PM   #999
NevEno
NevEno's Avatar
Lookin good!!
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 11-14-2016, 02:25 PM   #1000
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by NevEno View Post
Lookin good!!
Thanks man!
