09-16-2016, 11:55 AM | #2701 |
Re: PO has me PO'd
mornings progress, finished throttle body, searching connectors for air temp. sensor, installed heat shields
[url=https://flic.kr/p/Lk5SLD]
09-16-2016, 12:02 PM | #2702 |
Re: PO has me PO'd
09-17-2016, 12:26 PM | #2703 |
Re: PO has me PO'd
mornings progress
fuel injector harness O2 sensor harness Taylor high temp wires shields [url=https://flic.kr/p/Mg5XXE] [url=https://flic.kr/p/Mg5XY1]
09-17-2016, 05:52 PM | #2704 |
Too Dumb To Know Better
Re: PO has me PO'd
Getting closer Jim.
Looks like you need a few bolts in you exhaust manifold. Take Care. |
09-19-2016, 10:50 AM | #2705 |
Re: PO has me PO'd
thanks Doug, labor of luv,ahhh another lol
whatcha bin up two? I think all the bolts are in, just need to torque unless you mean t he cast in boss and then their was two.....just new air temp. sensor, o2 weld to downpipe [url=https://flic.kr/p/MdyhtN] [url=https://flic.kr/p/Mdyhuu] we need another what's in the safe thread
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-19-2016 at 10:56 AM. |
09-21-2016, 10:29 AM | #2706 |
Re: PO has me PO'd
tired of trying to line up bolt and shield at the same time. used a 1" hex drive ss stud with aflange serrated nut
[url=https://flic.kr/p/LuVaRG]
09-22-2016, 12:24 PM | #2707 |
Re: PO has me PO'd
tomorrow it rolls out of the work shop, to put the bridge port in
09-22-2016, 11:46 PM | #2708 |
60-66 Nut
Re: PO has me PO'd
I'm jealous........
09-23-2016, 09:06 AM | #2709 |
2WD Jimmy
Re: PO has me PO'd
[QUOTE=. used a 1" hex drive ss stud with aflange serrated nut
Be sure and use some copper anti seize compound on that SS hardware. |
09-24-2016, 07:47 PM | #2710 |
Re: PO has me PO'd
[quote=Tom Vogel;7721770][QUOTE=. used a 1" hex drive ss stud with aflange serrated nut
Be sure and use some copper anti seize compound on that SS hardware.[/quote] it fits cap'n, I guess she stays tom, thanks for the reminder, how about nickel, instead of copper. I think it has higher temps. [url=https://flic.kr/p/Mrhdhz]
09-24-2016, 07:50 PM | #2711 |
Re: PO has me PO'd
first time in the light of day in 15 years
[url=https://flic.kr/p/MrhdhV] [url=https://flic.kr/p/Mrhdig]
09-25-2016, 12:40 AM | #2712 |
60-66 Nut
Re: PO has me PO'd
Yep, it looks like she fits.........just don't get too engrossed in machining something and forget about that step over to the right
[quote=jaros44sr;7723207]
09-25-2016, 09:59 AM | #2713 |
2WD Jimmy
Re: PO has me PO'd
Copper is the high heat stuff.
PS... I want a mill like that. So useful. |
09-26-2016, 08:59 AM | #2714 | |
Re: PO has me PO'd
[url=https://flic.kr/p/MaQVwE]
09-27-2016, 12:39 AM | #2715 |
60-66 Nut
Re: PO has me PO'd
You are kidding me! Around here a Bridgeport like that would go for about 10X that. A wore out Bridgeport would still be $2K+.
09-27-2016, 11:11 AM | #2716 |
Re: PO has me PO'd
well, we lost a lot of manufacturing in this area, auctions for this stuff is all over the place. MAYBE I should buy it up and deliver out there
09-27-2016, 03:17 PM | #2717 |
Re: PO has me PO'd
10-10-2016, 11:48 AM | #2718 |
Re: PO has me PO'd
10-10-2016, 11:59 AM | #2719 |
Can't wait to retire!!
Re: PO has me PO'd
That's a nice light, but it may obstruct your view slightly driving down the road?
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
10-10-2016, 12:57 PM | #2720 |
Re: PO has me PO'd
[QUOTE=jaros44sr;7724548]Thanks Tom for setting me straight. Machinery is pretty cheap around here, I only paid 400 for this one, even came with a electric cross feed and vice.It's 3 phase, so I have to change the motor. there is a bearing company that wants me to key shafts for them, so I will have work this winter
What voltage is your motor? If it's 208, keep the 3 phase and use a variable frequency drive(VFD). I run a few of my machines this way and now prefer small 3 phase motors over single phase because I can make them variable speed. Best part is that a VFD is relatively cheap to buy. |
10-10-2016, 05:48 PM | #2721 | ||
Re: PO has me PO'd
[quote=hemi43;7738365] Quote:
10-11-2016, 10:27 AM | #2722 |
Re: PO has me PO'd
just came to me who was posting up, talk about a blast from the past, how's the boys? What have you been up to....
10-11-2016, 10:31 AM | #2723 |
Re: PO has me PO'd
Dan, spent a little more time searching, and came up with a VFD for the Bridgeport, much better than the noisy rotary drive. Thanks for getting me back on track
10-11-2016, 03:30 PM | #2724 | |
Re: PO has me PO'd
All you need now is some ball screws and a computer !! |
10-11-2016, 06:43 PM | #2725 | |
Re: PO has me PO'd
Weird, to run into 2 phase, but its a philly and Rochester thing, from way back in the day. found out about it on practical machinist
