Old 09-16-2016, 10:50 PM   #1
Zoomin
Man of Mini-Talents
Zoomin's Avatar
54 GMC 100: The Iron Ox
Iron Oxide, aka Fe2O3, more commonly known as rust is the first thing anyone will notice about this truck. It has it on every panel, and on the frame. It has rust outs in numerous places, but not in the main places. So far it seems worthy of putting back on the road, so I'll mainly be concentrating on doing exactly that.
No fancy frame swaps, clips, fancy paint or LS's are in the cards for Ox, just make it safe to drive, stop the rust, and a decent stance. It came with a 350/700R combo of questionable condition - it's in there but has never moved Ox an inch. It won't start and it has no brakes, a new wiring harness that has not been installed. It's a project someone smarter than me bailed out of.
Zoomin is offline   Reply With Quote
Old 09-16-2016, 11:07 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 54 GMC 100: The Iron Ox
Old 09-17-2016, 08:23 AM   #3
Katrina/10
Katrina/10's Avatar
I like it. You may run into an issue with the driver's side exhaust manifold, too.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-17-2016, 11:06 AM   #4
iowaboynca
iowaboynca's Avatar
Gotta love them !
Love the name! Sounds like a straight forward project!
Good luck.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-17-2016, 08:00 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Fortunately the PO found a set of OEM cast manifolds that clear the steering box and the frame, so I may have lucked out there.
Originally Posted by iowaboynca View Post
Gotta love them !
Good luck.
Yeah, it should be straight forward but I rarely luck out that way, and my goal posts keep moving as I get into it.
Thanks for stopping by, guys!
Old 09-18-2016, 09:12 PM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Taking on a project like this has me a bit overwhelmed- so much to do, take stock of, decide on a plan of attack and come up with a vision of where I want to end up.
Those who fail, fail to plan - right?
So anyway, I'm still in the early stages of each of those things. First thing I had to do was replace those gawd awful rollers with a set of Boyd Coddington Timeless wheels I had squirreled away. The 17x9 wheels with 275's fit, but just barely. Luckily the front and rear bolt pattern is 5x4.75 so I've got lots of wheel options when the time comes to get the actual set to be used.
Old 09-18-2016, 11:34 PM   #7
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice Patina!
ChuckDriver is offline   Reply With Quote
Old 09-21-2016, 08:18 PM   #8
rusty76
rusty76's Avatar
I'm in.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-21-2016, 09:00 PM   #9
joedoh
joedoh's Avatar
haha been there! good luck!
Old 09-21-2016, 11:43 PM   #10
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I gotta admit something here. I mistakenly thought doing the ole patina thing would be a whole lot easier than it's turning out to be. I should buy PB Blaster by the drum. I have rounded off more bolt heads and stripped more threads than all my other builds combined.
And the grill. Cripe O Mighty. The peeling paint on it bothered me, so I thought I'd get it blasted, right? Can't get to the bolt heads because there's at least 4 layers of paint. So I get paint stripper. And I scrape, and scrape, add more stripper and scrape. More bolt heads round, threads strip and the sucker is still on.y
Thoughts of a plasma cutter enter my head briefly, but I decide to just strip the damn thing on the truck. So after hours of applying CLR and not getting anywhere fast, I use a wire brush, graduated to a wire wheel and then to an angle grinder dammit.
Another couple days and one of us will be whipped.
Old 09-22-2016, 12:45 AM   #11
joedoh
joedoh's Avatar
sheeeeooot. I have a chrome gmc grille hanging in the shed I was almost giving away a couple months ago. I need it for my 49 GMC though, which has a beat up grille of its own.
Old 09-22-2016, 12:46 AM   #12
iowaboynca
iowaboynca's Avatar
Wow...there some metal under there!
Old 09-22-2016, 01:47 AM   #13
Nut Case
Nut Case's Avatar
OX
I use 50% acetone with 50% any atf. Works better and less cost than the stuff in a can at 8 buck a pop, get a spray bottle like you use to spray windex. I spray once and wait 24 hrs use heat OxAc, then spray again and wait 24. If it is still not giving, then I get two long box end wrench's and bust it up, if that doesn't work get the fire wrench.
Project looks good, making head way on the grill.
Keep on keepin on
Nut Case
ps I have a 57 GMC disassembled down to the frame scattered between two states. I'm downsizing. No Joy
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-22-2016, 08:44 AM   #14
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks great man!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-22-2016, 10:37 AM   #15
knomadd
knomadd's Avatar
Nice, I'm in. If you want the patina look still, just paint the grille and leave the body. Not something I like to suggest, but you cold always do a faux-tina on the grille if you don't like the painted look on a true patina body.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-22-2016, 10:58 AM   #16
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Hi Duane, thanks for dropping in. I won't have to do any faux-tina - all I need to do is leave it alone and it will rust up all by its lonesome. I could use steel wool to maintain it if I don't paint it I suppose. I would like to do something to stop the rust from being the surface type to graduating to scale or worse. It's amazing how the steel on the grille and surround has held up while the bolts have all given up.
Old 09-22-2016, 10:59 AM   #17
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Joe, just noticed the cab in your pic is sporting some of the same green that mine has. I wonder if that was a primer or ?
Old 09-22-2016, 07:54 PM   #18
Zoomin
Man of Mini-Talents
Zoomin's Avatar
UPS truck came by today. Got enough stuff to keep me busy over the weekend, including these Dolphin gauges
Replacing these:
Old 09-22-2016, 09:51 PM   #19
Advanced Design
Advanced Design's Avatar
I'm in, tagging along.
Advanced Design is offline   Reply With Quote
Old 09-22-2016, 11:28 PM   #20
joedoh
joedoh's Avatar
on my truck the green is the original color of the truck, the red is the primer. similar to Henry Fords famous quote, I can seem to find trucks in any color as long as they are green. this is my fifth green truck.
Old 09-23-2016, 12:21 AM   #21
iowaboynca
iowaboynca's Avatar
Ho ho ho....GREEN GIANT!
Old 09-23-2016, 01:11 AM   #22
iowaboynca
iowaboynca's Avatar
double type
Old 09-24-2016, 09:23 PM   #23
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I've got an Ox to grind - worked on the tailgate today
Turns out most of the crusty stuff is paint curling up. The top layer is a skim coat and white, below that is a dark brown, followed by a dark green and then finally a light blue. I'm using an angle grinder with a flapper disk with light pressure. When I hit the green I know it's time to ease up because the blue is underneath.
Not sure why I'm keeping the blue, I guess it's kinda cool the original paint has hung on so long and with all the others it's managed to keep the steel in surprisingly good shape.
Old 10-04-2016, 11:32 PM   #24
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Working on the wiring now, got a fuse box installed so that the main wiring harness is protected. Also setting up a common ground bar, a trick that proved useful installing LS's. The main power lead from the battery connects at the bottom, and I have the power lead from the alternator attached on the right. One advantage to hooking up the alternator this way is that the fuses take the hit before the diodes.
Ok, I have some work cut out for me here....
Old 10-05-2016, 10:34 AM   #25
joedoh
joedoh's Avatar
looks like a pot of spaghetti blew up!
