#501 | |
Re: 1991 V3500 Project Heavy Hauler
He works for TK and Bilstein?
#502 |
6>8 Plugless........
![]() Join Date: Sep 2007
I got the impression that TK either owns Bilstein or they are associated some how.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#503 |
Got the drag link installed last night. No cone washer. Just keep beating on it and lots of pb blaster... Exhaust shop scheduled for next Thursday.
Appreciate the info on Bilstein. I am going to run the Napa one for the time being.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#504 | |
I didn't know that. Looks like TK has owned them since 1988.
#505 |
What are your exhaust plans?
#506 |
Going to have the shop connect my header collectors to the y-pipe. Noting too exciting. Going to change the routing slightly though so I can change my fuel filter in the future.
#507 |
Coming along, seeing you replace the drag link / tie rod makes me feel like I need to replace all of my steering parts in the K10. I'm not sure if it's all worn out or it's just a 30 year old solid axle truck!
#508 |
Marcus,
I just went back through reading this thread. I was wondering if you could give me more info on the duplicolor paint you used on the floor and speaker brackets? I belive tge grey on my truck is the same color as yours.
#509 |
Yep I'll do some searching tonight and see if I can come up with a part number. It has held up well.
#510 |
Thanks!
#511 |
BGM0534 Search for this bad boy at Napa.
#512 |
Awsome!!
Thanks!
#513 |
Dirty Larry told me I was a punk for not checking out this awesome thread before. I've always trusted Larry's advice, and it was another home run.
Your work is awesome and the build sheet only gets better with every new page. If you want to sell at any point the lady and I are always looking for an excuse to come back to AK! Fantastic! |
#514 |
Hahaha thanks Ryan. I think my wife would kill me if I sold it after all this work. You will LOVE the bbc I. Front of a 4l80e. Great combo. I'm dying to put some miles on mine now they it is tuned.
It has been in exhaust jail for almost two weeks. Hopefully I will get it back early next week. This time away from the crew cab has me pacing around the plow truck making plans.
#515 |
That thing is sweet too! I think a turbo on a 292 would be kind of neat...
#516 | |
I just don't understand how an exhaust shop could keep your truck so long, that's rediculous!!
#517 |
there just milking it
it simply doesnt happen in the netherlands , you need to make an apointment for a custom exhaust say 2 or 3 days in advance but they build it while you wait at the reception area be done in about one or two hours drive in and drive out
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#518 |
Finally got the truck back on Thursday. Friday I got a call saying don't drive your truck, the passenger side wheel bearing is toast and has a ton of play. I had asked them to look through the front end and picked up the truck without talking to the mechanic. Sure enough I jacked it up and there was about 3/4" of slop at the hub. I started to disassemble expecting mass carnage. Not very encouraging when I popped the hub selector off.
#519 |
The spindle jam nut was super tight, lock washer was not engaged to the pin on the spindle nut, and spindle nut was finger loose. Grease looked great. My guess is the lock washer was put in crooked, bound up and never reached the spindle nut. Must have just come loose recently because there was absolutely zero damage. I elected to reuse the timken bearings that where in it instead of the Chinese ones Napa had. Properly installed now.
#520 |
WOWSERS!
That could have really sucked! Definitely dodged a bullet!
#521 |
At least they notified you and you fixed it before it cost you more time and $$$!
#522 |
Ain't that the truth! They were two weeks out on any time to work on it. I wrapped up the passenger side today. Figured I had better check the drivers too. Loose. Pulled the hub out and it was shot. Damn snowballing projects. Those splines are not supposed to be beveled.
#523 |
Good thing I never throw anything away. These hubs came with the Dana 60 I owned briefly to put in my 77.
#524 |
Geez
The snowball is my life right now lol While I was fixing and painting the pinch weld for my windshield I noticed some substantial rust bubbles around my cab lights, it never ends! It's certainly nice to have what you need in the spare pile!
#525 |
Your repair turned out good! With the exception of the trans and t-case I'll have touched everything on this truck, which gives me a level of confidence to go far.
