Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-21-2016, 01:41 PM   #426
68Timber
I know the pieces fit
68Timber's Avatar
Re: How To: Ruin a Perfectly Good K/5
Dang that's a nice looking repair. My 85 has the same rot in both corners, I get to do this repair soon.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-21-2016, 02:44 PM   #427
gringoloco
A guy with a truck
gringoloco's Avatar
...and done. Including the big, boogery factory style weld holding the bedside to floor
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-21-2016, 02:46 PM   #428
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, I'm no professional, just try to take it slow and remember it's only metal.
-Chris
Old 09-21-2016, 08:43 PM   #429
gringoloco
A guy with a truck
gringoloco's Avatar
Thought I could get away with not cutting the stake post, but the good metal was just a little too deep. This side is going easier than the drivers, partly due to no extra stuff in the way, and partly due to the learning curve.
The cross sill is patched and the floor patch is fitted. Need to punch the plug weld holes and she's ready to burn in. Taking it easy tonight, so I'll weld it in the morning. Thanks for tagging along
-Chris
Old 09-23-2016, 12:32 AM   #430
gringoloco
A guy with a truck
gringoloco's Avatar
Done and done. Pass side patch did not line up as well for whatever reason. Took a little extra persuasion to coerce the ribs into alignment. Metal straightened and body-worked the drivers side as well. I'm through with this area until final prep for paint
Looks like it's time to move on to the A and B pillars, which I am not looking forward to. I am, however, looking forward to coating the insides of the rocker boxes in POR--this stuff is addictive
-Chris
Old 09-23-2016, 08:10 AM   #431
mcbassin
Still Learning
mcbassin's Avatar
Excellent work on the rust repairs Chris. You made that look way too easy
Old 09-23-2016, 08:26 AM   #432
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, Mike. The pictures don't do justice to all of the cutting/fitting/grinding/welding that goes into the repairs. Honestly, this is my first time attacking rust this extensive; I learned most everything I'm doing here by watching folks like you on this board.
-Chris
Old 09-23-2016, 11:22 AM   #433
gringoloco
A guy with a truck
gringoloco's Avatar
Randomly selected B pillar first. I've seen worse...
-Chris
Old 09-23-2016, 12:03 PM   #434
gringoloco
A guy with a truck
gringoloco's Avatar
Done cutting(?) for now. Leaving as much of the existing metal as I can.
Rocker box is super solid. Time to POR inside the B pillar, while it's accessible.
-Chris
Old 09-23-2016, 02:51 PM   #435
gringoloco
A guy with a truck
gringoloco's Avatar
First patch in and POR'ed: I only ground the welds that have a chance of being seen
-Chris
Old 09-23-2016, 05:44 PM   #436
gringoloco
A guy with a truck
gringoloco's Avatar
Built a template for the next piece and burned it in:
-Chris
Old 09-23-2016, 06:58 PM   #437
lolife99
67-72 parts collector,…
lolife99's Avatar
You do great work!
Keith
Convert to disc brakes.
Old 09-23-2016, 07:21 PM   #438
gringoloco
A guy with a truck
gringoloco's Avatar
You do great work!
Thanks, man. All I know is I do slow work
Finished the outside of the support; still need to work the leading edge then it's ready to be skinned. Looking at these pictures makes me want to grind the welds in there--I need to get it buttoned up soon to quell the urge to perfect it. Ended here for the day:
-Chris
Old 09-24-2016, 04:07 PM   #439
gringoloco
A guy with a truck
gringoloco's Avatar
Cut a piece for the front side of the support and fitted a 95% solution for the outer skin:
-Chris
Old 09-25-2016, 09:15 PM   #440
gringoloco
A guy with a truck
gringoloco's Avatar
Tack, tack, tack, grind, tack, tack, tack, grind, sand, prime. It needs a little hammer/dolly and a skim coat of filler.
-Chris
Old 09-25-2016, 09:41 PM   #441
gringoloco
A guy with a truck
gringoloco's Avatar
Then the A pillar... HartRob, in his Superburb thread, described this area as a five-dimensional puzzle. I tend to agree. Everything comes together in the same place, then traps dirt/moisture and rots it all.
I cut out all of the offensive metal, including floor, inner rocker, kick panel, A pillar, floor support, and a small bit of the rocker box directly under the support. Decided to patch the support, as opposed to replacing it, as there was only a small area gone and the replacements I received are paper thin garbage--I used a scrap of one of the fender patches to repair the existing piece. Followed that with buttoning the rocker box back up, then ended the day with POR-ing as much of the inside of the box as I could reach. Next up: 5D puzzle
-Chris
Old 09-26-2016, 01:13 AM   #442
Chulisohombre
Chulisohombre's Avatar
God work
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-26-2016, 08:34 AM   #443
mcbassin
Still Learning
mcbassin's Avatar
You are doing incredible work on the metal replacement. Honestly, it's exactly this kind of series of pictures that made me believe it was easy enough for me to tackle.
I know good and well how much effort that went into the finished product.
Looking forward to watching the rest of the front pillar repairs.
Awesome work as always!
Old 09-26-2016, 08:47 AM   #444
lks dcvn
lks dcvn's Avatar
Awesome job! You made that look easy. Having been in those sections before - I know that is not fun sometimes.
lks dcvn is offline   Reply With Quote
Old 09-26-2016, 10:42 AM   #445
aggie91
I'm just glad to be here!
aggie91's Avatar
Your work looks good. While I enjoy metal work, doing this kind of work is not at the top of my list.
Keep the pictures coming!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-26-2016, 12:21 PM   #446
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Chulisohombre View Post
God work
Thanks!
Appreciate it, man. That's my thoughts, too--seeing others' accomplishments inspired me to tackle the job myself. Hoping to give back a little
Thanks--your work and others proved to me it is possible. It is a little fun and therapeutic, but can become droning (and time consuming).
Thanks a lot! Not my first choice of things to do, for sure, but the payoff will be huge when it's complete. Pictures will slow a bit, as I'm back to my day job again...
-Chris
Old 09-28-2016, 12:58 AM   #447
gringoloco
A guy with a truck
gringoloco's Avatar
Welded some square nuts on the back side of the floor support, like I've seen many others do. Will not have access to inside the rocker box when it comes time to tighten the four bolts through all these sheets of metal. Spent some time bending, shaping, fitting, welding, and grinding the floor patch. Next is the front section of the inner rocker, then kick panel, and finally, A pillar. Once that's all in, I'll be ready for the outer rocker and done with this side
-Chris
Old 09-29-2016, 12:07 AM   #448
gringoloco
A guy with a truck
gringoloco's Avatar
...and finished off the floor to inner rocker transition. Still some tweaking to do as I fit the kick panel patch, but it is all coming together...
-Chris
Old 09-29-2016, 05:52 PM   #449
thor
thor's Avatar
Repairs are looking great! This was already a good looking Blazer. Now it's going to be even better!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 09-29-2016, 11:57 PM   #450
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, man! This rust has been really bugging me...
Got the kick panel fitted and burned in, then rough first fit on the A pillar. Not super happy with the quality of the pillar piece, but it will be hidden when all is said and done. This 5D puzzle is kicking my ass--hopefully the other side goes smoother...
-Chris
