Old 09-21-2016, 03:16 PM   #1
Pete1stark@yahoo.com
Engine, Trans, Rearend swap
What sort of pitfalls are there is installing the engine, auto trans, and rearend from a 1987 Corvette into my 53 Chevy pickup? It has a small block, th350, and late model camaro rearend in it now. But the rearend is about 3 inches (overall) too wide and the corvette is narrower by 3 inches. And I can get the Vette insanely cheap.
Pete1stark@yahoo.com is offline   Reply With Quote
Old 09-21-2016, 03:46 PM   #2
mr48chev
mr48chev's Avatar
Re: Engine, Trans, Rearend swap
A couple of outfits make kits to install that model of Corvette rear ends in AD pickups pretty much making it a bolt in.
The engine and trans should bolt in where the other small block came out with maybe having to move the trans mount and or possibly needing to use a short water pump for radiator clearance if the engine is mounted a bit forward for valve cover clearance.
The name of the outfits making the mount kits for the rear slips the mind right now and I don't have a copy of Classic truck here to look at but there is a thread on that running right now that should be on one of the first few pages of this board.
My ongoing truck projects:
Old 09-21-2016, 03:56 PM   #3
jams97355
I used Flat Out Engineering for my kit. There are others also.
jams97355 is offline   Reply With Quote
Old 09-21-2016, 07:27 PM   #4
Old 09-21-2016, 07:31 PM   #5
Old 09-21-2016, 07:35 PM   #6
What about the electronics / computers for the engine & trans. I heard that the purchase of an aftermarket computer/brain is necessary.
Old 09-21-2016, 09:02 PM   #7
iowaboynca
iowaboynca's Avatar
If you're going to use the vette as a donor, just pull the controls out of the donor. Hey, they're already designed to be compatible...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-22-2016, 12:22 AM   #8
Coupeguy2001
Coupeguy2001's Avatar
there is a corvette swap book by a company called JTR, (jags that run). They cover everything from bumper to bumper.
Coupeguy2001 is offline   Reply With Quote
Old 09-22-2016, 12:35 PM   #9
1project2many
The '87 Vette computer will work well enough for a stock or mild engine. You can have someone make a "custom" chip to address specific changes, such as shutting off the Vette security system and changing speed calibration if you use different size tires. If you are considering powertrain upgrades then do some research as some choices will cause more heartache than others. One thing to note as that Corvettes of that vintage often came with notoriously low (numerically) rear end gears. 2.59 and 3.07 gears aren't uncommon with an auto trans. Another factor to note is there are two rear differentials available. The more desireable Dana 44 is found behind manual transmissions while autos were equipped with a Dana 36.
1project2many is offline   Reply With Quote
Old 09-23-2016, 03:00 PM   #10
Ok. But the Corvette got away from me while I was getting info for the swap out. I wanted it primarily for the rearend. This is mainly due to not knowing what is in my truck now. I was told from the guy I got it from, it was out of a gem lV Camaro. But thru an exhaustive effort I haven't seen able to confirm that. Is there any literature out there that will tell, definitely, how to identify a late model GM rearend without tearing it down?
Old 09-24-2016, 10:56 PM   #11
Coupeguy2001
Go to Chevy High performance magazine website.
About 10 years ago, they did a blurb on how to tell what rearend you were looking at in a junk yard,
it primarily shows cover plate, and rear end tags, and what to look for.
Old 09-25-2016, 07:47 PM   #12
Rude Dude
Rude Dude's Avatar
First on GM models there is the casting number that tells you if it is a 10 bolt or 12 bolt etc...
Second on the passenger side of rear axle tube there is two alphabet to tell you what the gear ratio came with it and if equipped with posi
Third the axle numbers correspond to month and year it was built and sequence number built that year.
Fourth the last alphabet number tells you which of the four GM plant it was built at.
Rude Dude is offline   Reply With Quote
Old 09-25-2016, 07:52 PM   #13
Rude Dude
Rude Dude's Avatar
This might help
REAR AXLES
Outside
Width Year Model
58.00 1978-1988 Chevy Malibu, Monte Carlo
60.00 1955-1964 Chevy Car
60.00 1967-1969 Camaro
60.25 1968-1979 Chevy II/Nova
60.50 1964-1967 Chevelle
62.00 1955-1959 Chevy Pickup
62.50 1970-1981 Camaro/Firebird
64 1965-1976 Impala
1968-1972 Impala/ Chevelle
