Old 09-22-2016, 12:04 PM   #1
Willie Makeit
Willie Makeit's Avatar
71-72 vs 73-8x? A-Arm questions
Gents
Are the '73 & up A Arms dimensionally the same as 71-72 A-Arms?
Meaning, will cross shafts & ball joints for 71-72 models fit in both upper & lower 73 up A-Arms?
Thanks!
Willie Makeit is offline   Reply With Quote
Old 09-28-2016, 10:30 AM   #2
SCOTI
SCOTI's Avatar
Re: 71-72 vs 73-8x? A-Arm questions
6x-72 C10's use a different type of bushing vs 73-87's so the shafts are different.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-28-2016, 03:29 PM   #3
Willie Makeit
Thank you sir!
Old 07-08-2018, 10:49 PM   #4
jondancer
If I bought a complete 73+ Upper control arms , would they bolt up to my 71 ?
jondancer is offline   Reply With Quote
Old 07-09-2018, 09:59 AM   #5
SCOTI
SCOTI's Avatar
They will physically bolt-in place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2018, 12:18 PM   #6
Clyde65
Clyde65's Avatar
The 73 and up are easily rebuildable if needed, parts are cheaper that the 63-72( ie ball joints etc) and more readily available too. You will need to open up the u-bolt holes a bit to accommodate the larger u-bolts from 73 and up.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
