Old 09-22-2016, 05:27 PM   #1
Smokintire70
700R4 torque converter questions.....
Some one told me a 700r4 does not use a torque converter. I have also have heard that they do use one. If one could specify whether they do or don't that would be sweet. I want to put a cam (272 or 292 Comp hyd roller ) in my ramjet 350. Thanks guys.
Smokintire70 is offline   Reply With Quote
Old 09-22-2016, 07:06 PM   #2
LongBox
Re: 700R4 torque converter questions.....
the 700R4 does use a TQ. Think of it as a TH 350, with an overdrive gear, and a lock up torque converter.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 09-22-2016, 09:12 PM   #3
Low69CST
Without the lock up feature OD is pointless. The rpms will be below the stall level and the converter will allow slippage.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 09-22-2016, 09:14 PM   #4
hugger6933
Yep does have a converter. My thinking is on the cam is the cam gonna play nice with the ramjets electronics? I thought they were non-programmable.
hugger6933 is offline   Reply With Quote
Old 09-22-2016, 09:18 PM   #5
Bigdav160
Bigdav160's Avatar
I would think a little more stall in the converter is warranted with those cams. The lockup feature can be done without electronic control if the controller won't handle it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-23-2016, 12:25 PM   #6
davepl
davepl's Avatar
It does have a TC, normally a lockup unit in factory config. For a 292 cam, you might need/want a looser converter.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-23-2016, 06:25 PM   #7
Smokintire70
What is a lockup? Does it lock the engine and transmission at a certain rpm?
Old 09-23-2016, 07:35 PM   #8
leftybass209
leftybass209's Avatar
Since you don't know much about the overdrive transmissions, you should go to bowtie overdrives website and do a lot of research. Putting an OD trans in a vehicle without understanding what's going on can result in a vehicle that runs like crap, a transmission that will burn up, or most likely both.
You have to consider cam spec, rear gears, RPMS for stall, 1st gear ratio, throttle valve connection, driveshaft length, transmission crossmember.... it's not a bolt and go affair 99% of the time.
leftybass209 is offline   Reply With Quote
Old 09-23-2016, 07:37 PM   #9
leftybass209
The show Trucks! Once installed a 700r4 behind a 6 in a 49 chevy, you may want to search for info on that as well.
Old 09-24-2016, 01:29 PM   #10
davepl
davepl's Avatar
Yep. Strategy varies by model, but in most cases they won't lock up unless the transmission is in D and you're at a certain output speed. And there's usually integration with the brake switch so that it unlocks whenever you touch the brakes.
Ideally you'd never feel or know it's doing it, but it helps for mileage as there's then no slip, as opposed to just a little.
