Old 09-18-2016, 03:04 PM   #1
dragn91
dragn91's Avatar
Anyone have a under hood wiring diagram for a 84 6.2 diesel
Im trying to get rid of all the previous owners wiring add ons but i want to make sure i dont screw up the trucks running ability. Im new to the 6.2 diesels so im not sure what all is suposed to go where ect.. wondering if anyone had a wiring diagram.
dragn91 is offline   Reply With Quote
Old 09-18-2016, 05:31 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Anyone have a under hood wiring diagram for a 84 6.2 diesel
PDF is available. Look in my signature...
When you buy the used paper the wiring diagrams are not separate they're in the last chapter of the service manual.
This 1984 GM factory service manual on Evilbay is in ABE BOOKS Fair Condition.
http://www.ebay.com/itm/1984-GMC-Lig...1XKXFB&vxp=mtr
Download the PDF copies and you'll see exactly what you would be buying... Once you have the paper you have fair use for the PDF.
ABE Books conditions explanation
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-19-2016, 02:03 AM   #3
Gmc.guy
Gmc.guy's Avatar
I have an unmolested 84 2wd 6.2 with a/c if you need some pics or have any questions.
-Cody
Gmc.guy is offline   Reply With Quote
Old 09-19-2016, 02:57 PM   #4
barry1982
I can also help out with 6.2 stuff.... have eight 6.2's ranging from 82- 92.
barry1982 is offline   Reply With Quote
Old 09-19-2016, 05:20 PM   #5
dragn91
dragn91's Avatar
Thanks. Yea a nice underhood shot of a unmolested 6.2 would be great i just pulled a bunch of extra wiring last night but i got alot to go i swear this this was wired for a dozen different trailer lights and brakes and just as many cbs and who know what all else.
Old 09-19-2016, 10:23 PM   #6
Gmc.guy
Gmc.guy's Avatar
Cool. I'll be out in the shop tomorrow I'll throw a couple pics up in here for you. Let me know if there are any detail areas you might need
-Cody
Old 09-25-2016, 12:54 PM   #7
Gmc.guy
Gmc.guy's Avatar
Sorry, finally found some time. Here's the glow plug controller
-Cody
Old 09-25-2016, 12:55 PM   #8
Gmc.guy
Gmc.guy's Avatar
2.
-Cody
Old 09-25-2016, 12:57 PM   #9
Gmc.guy
Gmc.guy's Avatar
3.
-Cody
Old 09-25-2016, 12:58 PM   #10
Gmc.guy
Gmc.guy's Avatar
4.
-Cody
Old 09-25-2016, 01:01 PM   #11
Gmc.guy
Gmc.guy's Avatar
Fuel filter
-Cody
Old 09-25-2016, 01:03 PM   #12
Gmc.guy
Gmc.guy's Avatar
One went right side up? I'll work on that. The two extra red wires with the yellow connectors at the junction block were camper charge wires I can take better detail pictures if you like. Sorry it's dusty Tough to take decent pictures
-Cody
Old 09-25-2016, 02:17 PM   #13
hatzie
Moderator
hatzie's Avatar
Cody. That's just the contactor. The round 6 terminal controller will be in the front Right Corner of the intake manifold. The round controllers are fine as long as they work. The replacement round controllers are not made in the US and they don't last long.
The 1985 - 2001 6.x L glow controller is an easy replacement. Mount it where the contactor is right now.
Fuel filter
That Stanadyne 80 box filter tends to leak like a sieve. The stock 1995-2001 6.5L Diesel Stanadyne Filter manager mounted in the intake valley is a better choice. Brand new 1995 Stanadyne FFM costs right around $125 complete filter, housing, Water in fuel sensor, and heater.
Old 09-25-2016, 03:38 PM   #14
Gmc.guy
Gmc.guy's Avatar
That's what I meant. It works well and I don't intend to change it, thanks for the tip if I ever need to. The old filter didn't leak and I had no problem with this one yet. I have seen several use these and never heard of a problem. This isn't an upgrade truck or a driver. I start it a few times a year and maybe 200km a year tops. I just want to keep everything working and from ceased up. I don't intend to update it or get any performance out of it
-Cody
Old 09-25-2016, 03:41 PM   #15
Gmc.guy
Gmc.guy's Avatar
I have a catch can and keep the spillage from splashing everywhere when you change it out. That's my only complaint with it I guess with the fuel filter
-Cody
Old 09-25-2016, 05:20 PM   #16
hatzie
Moderator
hatzie's Avatar
The housing around water in fuel sensor tends to corrode and leak eventually. If it's working right now and you can get good quality filter cartridges keep it. The FFM is much easier to service and you can get parts for it.
If you burn out the round 6 pin timer and thermostat module don't expect a new one to last more than a few weeks unless you somehow luck into a real GM unit from the 1980's gathering dust on some shelf.
The 1985-2001 controller can be calibrated for the AC60G Positive Temperature Coefficient self regulating glow plugs. The old AC 9G & 11G glow plugs swell up when they fail the AC60G and other PTC glow plugs don't usually do that. I've done the curse and swear and get red in the face bit removing what's left of old school swelled up glows through the injector hole on GM & VW diesels.
Old 09-26-2016, 12:02 AM   #17
Gmc.guy
Gmc.guy's Avatar
I put new exhaust on the truck 2 summers ago. I had to pull the manifolds to replace the studs and I pulled the glow plugs and they looked new too so I put the new ones on the shelf. The truck high idles still when cold and the glow plugs cycle well like they should. Idles up when a/c is turned on cruise works It's a miracle truck. Haha I found tighten everything up good and tight because even the manifold and power steering pump brackets rattled loose in no time. The old timer that had this truck got it new when he was 60+ and took real good care of it
-Cody
Old 09-26-2016, 12:05 AM   #18
Gmc.guy
Gmc.guy's Avatar
Maybe I'll Cummins it one day and give Barry1982 a steal-of-a-deal on some low mile parts. Haha. (About 2.5 hours away)
-Cody
Old 09-26-2016, 12:04 PM   #19
barry1982
LOL Never know Cody.....heaven knows I love my old 6.2's.....Been running them since the early 90's. Wore out quite a few.....
