Old 09-25-2016, 10:23 PM   #1
JORGIE95961
Idles rough in gear
th350 sbc 350 hei, changed plugs wires, cap rotor no change. running carter afb. was running great and then bam. i hit a stop sign and it wants to die. power brakes and parking brake same reaction. idles great in park. again it was running great ,until it didnt.. i wanna believe its someting like a bad tork converter trying to force my tranny to move my rear wheels. any advice is apprecieated
JORGIE95961 is offline   Reply With Quote
Old 09-25-2016, 11:28 PM   #2
geezer#99
geezer#99's Avatar
Re: Idles rough in gear
Check your timing!
Old 09-26-2016, 12:25 AM   #3
garyd1961
How old is the motor and how many miles on it? It sounds like a vacuum leak, bad carb, or worn out cam. In my case it was a worn out cam.
garyd1961 is offline   Reply With Quote
Old 09-26-2016, 01:18 AM   #4
swamp rat
swamp rat's Avatar
Vacuum leak, timing, air fuel mixture screws, worn out carb. This assumes the compression and cam and timing chain are good. Also if the torque converter is engaging then the idle RPM is too high or possible a bad converter.
Once you can get it to idle, get friend to hold the foot on the brake while in drive and chock the tires, then try and fine tune the air fuel screws to smooth the idle out a bit more.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-26-2016, 04:22 PM   #5
1969c10joe
ok guys I DONT KNOW ANYTHING ABOUT AUTOMATIC TRANS. so you might get a chuckle out of this suggestion. Isnt there a vacuum line that goes to tranny modulator or something?I have a sm 465 so i wouldnt know
1969c10joe is offline   Reply With Quote
Old 09-26-2016, 05:41 PM   #6
custom10nut
custom10nut's Avatar
Before you sink a bunch of money into what it might be, get yourself a simple vacuum gauge and hook it up to the right side port on the front of you carb. You'll be amazed how many things you can diagnose with this simple tool. I'm attaching the chart of what the readings will tell you, so good luck.
custom10nut is offline   Reply With Quote
Old 09-26-2016, 05:47 PM   #7
1969c10joe
Originally Posted by webfoot View Post
If you have an SM465, that is a 4-speed manual transmission so there is no such animal, nor is there a torque converter.
you misunderstood my post read it again
Old 09-26-2016, 05:55 PM   #8
1969c10joe
you completely misunderstood my post please reread it
Old 09-26-2016, 06:04 PM   #9
1969c10joe
I am suggesting vacuum leak i always check easy fixes first I have a manual trans so i dont know the answer to this question but isnt there a vacuum line to his tranny? Like i said i wouldnt know because i have a sm 465.
Old 09-26-2016, 06:08 PM   #10
1969c10joe
im sorry about the duplicate posts I have no idea how that happens ill ask one of the kids in the neighborhood
Old 09-26-2016, 06:18 PM   #11
webfoot
I thought it was the OPs post and deleted it.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
