Old 09-27-2016, 09:10 PM   #101
NewType72
NewType72's Avatar
Re: New Daily Driver
I definitely second WarMongers idea of hardline all the way to the carb definitely safer than sorry
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-27-2016, 10:04 PM   #102
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Originally Posted by tune_1 View Post
Great to see you at work on another truck. The small steps look good.
Dwight
I have mixed feeling about the truck, I'm trying to keep the costs down but it's tough to do these days. People are paying high prices for these trucks and it's creeping into the parts side.
Originally Posted by Dieselwrencher View Post
Nice work on the truck, and the trans looks nice. Send Rob up here and have him do my side fill too would ya?
Thanks, It's tough to get on his schedule you're going to have to have your people get with his people.
Originally Posted by NewType72 View Post
Very sanitary build love it!
Originally Posted by 68Gold/white View Post
The steering column fiasco IS a lot of fun. Just don't force anything. It all fits together....
We'll see if I take this on or order one from Kevin at Kev's Classics.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 09-27-2016, 10:18 PM   #103
C10_ustacould
Originally Posted by WarMonger View Post
Good looking truck. Think about hard lining the fuel line from the pump to carb. these trucks burn down all the time for that reason and you have a good looking one. Hate to see it go up in flames.
I'll have to look into it but I was wanting to use one of these with all braided line and aluminum hardline in the frame rail. But I'm not sure it will work with the manual choke carb.
Y'all know your new vehicles have rubber hose in the fuel systems with much higher pressure, right?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-28-2016, 07:04 PM   #104
knomadd
knomadd's Avatar
I have (had) braided line from the pump to the carb on my small block. Since the pump is hard mounted to the block, there isn't a need for flexible line between the pump and carb. It's also a relatively maintenance free part if you go hard line. As opposed to having to check the flex hose (rubber or braided, still deteriorates much faster than metal) once in a while for cracks and failures and replace the flex line every so often.
You really only need the flex line between the frame and the pump to allow the line to flex with the engine/trans. As long as nothing else is a moving part, hard line should work fine. Also, most newer vehicles are using nylon (plastic) line since ethanol eats rubber pretty quickly. Heat becomes a concern with the nylon stuff though.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-02-2016, 01:11 AM   #105
gringoloco
A guy with a truck
gringoloco's Avatar
Watching this
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 10-08-2016, 01:46 PM   #106
C10_ustacould
Let's talk disc brakes. I'd like to upgrade to... No, I NEED to upgrade my brakes. I liked the performance of the 4-wheel disc setup I had on the stepside, it was a mix of ECE and CPP. Recently a well known builder warned me to stay away from CPP parts, I'm guessing he's seen some failures or quality issues. I like the fact that CPPs modular spindles keep the track width, but I'm more concerned about buying anything that may fail later. With this in mind I'm think of a couple scenarios. Opinions? Experiences?
1.) ECE 2.5" drop spindles with factory style single piston calipers, factory iron M/C with stock proportioning valve, and ECE rear drum upgrade kit. All this from ECE would be around $1400 + shipping
2.) Custom built 4 wheel disc brake kit using factory Corvette brake parts, McGaughy's spindles, and a Wilwood M/C with proportioning valve set up. $2500
3.) CPP 4 wheel disc kit. $1545 + shipping
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-09-2016, 01:00 AM   #107
gringoloco
A guy with a truck
gringoloco's Avatar
Keeping 15s? 6-lug? Have you looked into any of the captfab rear brackets? I think you can put together a 4 wheel disc setup for much less than those, unless you like the convenience of a kit.
Only issues I've ever heard of from CPP arise from customer service.
-Chris
Old 10-09-2016, 09:35 AM   #108
C10_ustacould
I am planning to keep the "15 Rallys, although I may buy a set of 15x10 for the rear. If I do buy new/different wheels it will likely be a smoothy with a stockish center cap so I won't need anything that looks fancy. The captfab brackets are great but I don't think he has anything that uses a caliper with a parking brake which is important to me. I'm really leaning towards the ECE disc/drum setup, it fits with my keep it simple and inexpensive intentions with this truck.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-09-2016, 11:16 AM   #109
C10_ustacould
WHOOPS! It looks like Captainfab has a bracket using 6 lug rotors and Eldorado or Camaro calipers. Going to have to look into it.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-09-2016, 11:25 AM   #110
Malamute
Malamute's Avatar
Just hopped in, I like the upgrades.
Malamute is offline   Reply With Quote
Old 10-10-2016, 04:49 AM   #111
Missed seeing you back into a truck. This one looks super good. Hope to see it at a future CTC event.
Old 10-10-2016, 06:29 AM   #112
C10_ustacould
Yep, it was tough to stay home from CtC this year, but I have to be smart with my vacation and my $$. Hope to see y'all next year.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-10-2016, 12:46 PM   #113
gringoloco
A guy with a truck
gringoloco's Avatar
C5 won't work with rallies (or many other wheels, for that matter). I say:
DJM drop spindles-$220
ECE 6-lug rotors-$200
Calipers, balljoints, etc from rockauto
Captfab rear setup
I think you can put it all together for around $1k, just guessing. Requires a little planning/leg work, but to mee, that's half the fun
-Chris
Old 10-10-2016, 01:03 PM   #114
knomadd
knomadd's Avatar
I agree with Chris. The only issues I've heard and read about with CPP are customer service driven. I personally bought the Modular drop spindles just to be able to run bigger brakes in the future and a bonus is the narrower track width. I just made sure to buy them from a board vendor so I didn't have to deal with CPP directly.
As for brakes, I went with Wilwoods, but I wanted the look too. I've read a few times that 4 wheel disc on a truck isn't really necessary, but if you plan on towing, racing or anything like that, it can't hurt. I hear McGaughy's and ECE are similar to the CPP kits for stopping power, but I don't have personal experience with any of them. Good luck!
-Duane
Old 10-10-2016, 01:15 PM   #115
Gus350
68 C 10
Gus350's Avatar
I like option #1
I like one phone call, one order. I don't have time to chase parts and hope I'm ordering the right ones.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 10-13-2016, 02:45 PM   #116
C10_ustacould
I ordered the first part of my brake upgrade today, and I am hopeful it turns out well. The quote, "There's a sucker born everyday" is bouncing around in my head. I ordered a master cylinder/proportioning valve and a pre-bent line kit from Performance Online. Never ordered from them so I'm cautious. Also, I tried the pre-bent lines from CPP with my stepper and because I swapped the '68 crossmember for a '73 my brake upgrade wasn't the norm, so I ended up not using their lines. Unfortunately, I have no idea what happened to those lines. Anyway, a friend of mine has a spare set of new 12" 6-lug rotors I can get on a deal and I'll be ordering CPP modular spindles and caliper brackets soon. Who on the board sells CPP? Everything else I can source at my local parts store. For now I'm going to try and get the rear drums working better with the front discs, but at some point I'll do a 6-lug rear disc conversion. I hope to have all of the parts required by the veteran's day weekend so I can take advantage of the extra day off to do the swap, can't have the daily driver down too long. We'll see...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-13-2016, 04:09 PM   #117
gringoloco
A guy with a truck
gringoloco's Avatar
Sounds like a solid plan. Do us a favour and measure before/after track width with the CPP modulars
-Chris
Old 10-13-2016, 04:24 PM   #118
C10_ustacould
Will do!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-13-2016, 04:36 PM   #119
knomadd
knomadd's Avatar
I bought mine from Matt from Matt's Classic Bowties, I believe his forum name is MCB Matt. He has several threads in the Vendors Marketplace.
-Duane
Old 10-24-2016, 05:09 AM   #120
C10_ustacould
Thanks Duane, I'll check with them.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-11-2016, 07:44 PM   #121
C10_ustacould
She gone!!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-11-2016, 08:06 PM   #122
Malamute
Malamute's Avatar
What? What's next?
Old 11-11-2016, 08:12 PM   #123
C10_ustacould
Originally Posted by Malamute View Post
What? What's next?
Don't exactly know yet. Maybe a convertible for my wife or maybe another C10, will be a few days to a week before we know.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-11-2016, 08:16 PM   #124
flashed
Convertible Chevelle's are fun ,I have one .
flashed is offline   Reply With Quote
Old 11-11-2016, 08:47 PM   #125
Advanced Design
Advanced Design's Avatar
Catching up ...reading about brakes and expecting to see brake upgrade pictures, nope...congrat's and have fun finding the next one.
Advanced Design is offline   Reply With Quote
