Old 09-29-2016, 12:58 PM   #1
flaa1a
flaa1a's Avatar
Mystery Firewall Grommet
Gonna start trying to fix some things on my rig. Can anyone tell me what this mystery hole is? Obviously missing the grommet and I am hoping to order one so I can get rid of the paper towel that was stuffed in it.
PS- all my pics keep loading sideways even tho they are right side up as I upload them.....any reason?
TIA
Randy
flaa1a is offline   Reply With Quote
Old 09-29-2016, 01:11 PM   #2
davepl
davepl's Avatar
Re: Mystery Firewall Grommet
The forum software doesn't recognize photos taken sideways yet, it's a bug in vBulletin. For now you can manually rotate them in a paint program before posting, that's what I have to do.
But to your question, it looks like two holes overlapped, which isn't original. You could maybe make a little plate that went over it with a single center hole and grommet. Others might have a better idea!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-29-2016, 01:21 PM   #3
flaa1a
flaa1a's Avatar
So at some point someone cut it!
Old 09-29-2016, 05:24 PM   #4
custom10nut
custom10nut's Avatar
Yup. That is your clutch rod hole, but yours has been cut. I agree with the cover solution. Just fab it to cover the hole and paint it to may have the firewall. Use a piece of foam to sandwich in between ti to seal out the weather
custom10nut is offline   Reply With Quote
Old 09-29-2016, 05:42 PM   #5
68is4me
68is4me's Avatar
I don't think that is the clutch rod hole. It looks like the speedo cable hole. But defiantly not the original hole size. Is the rubber grommet still on the cable? If it is you could just put the grommet back in the hole (if it still fits). A plate or weld a section in would be the correct way to fix.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 09-29-2016, 08:44 PM   #6
custom10nut
Oops. 68 is right. Speedo cable hole thes "been modified"
Old 09-29-2016, 10:01 PM   #7
flaa1a
flaa1a's Avatar
Thanks!!! Ill check it out to see if old grommet is on somewhere!
