Old 09-30-2016, 08:30 PM   #1
ck5566
Drag Link 2wd vrs. 4wd
I would like to know if there is any difference's in the 1/2 ton 2wd from the 1/2 ton 4wd trucks drag/center links. Here is a ruff drawing of what mine measures out to. Thanks in advance for any help.
ck5566 is offline   Reply With Quote
Old 09-30-2016, 10:22 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Drag Link 2wd vrs. 4wd
2wd vs 4wd are totally different. even the steering box sector shaft is different.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-01-2016, 01:31 AM   #3
'68 Newtricks
'68 Newtricks's Avatar
Even 1/2 ton VS 3/4 ton 2wd trucks are different. Hole taper is different.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 10-01-2016, 11:02 AM   #4
ck5566
I should have said my truck is a 68 C10 6cyl if that matters and non power steering if that also matters. Also is the Angles different at the points where the Pitman Arm & Idler Arm & the Tie Rod Ends are in relation to each other from the 2wd to the 4wd Trucks, Thanks again in advance
Old 10-01-2016, 11:07 AM   #5
Bigdav160
Bigdav160's Avatar
4WD doesn't use parallelogram linkage but rather push - pull with toe rod
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-01-2016, 11:14 AM   #6
ck5566
NOW you got me there, can you explain that "parallelogram linkage" but rather push-pull with toe rod mouth full of word thing to me. LOL on the last sentence.
