![]() Join Date: Feb 2004
FS Lower shock brackets. Fresh powdercoating
I have a set of old style shock brackets. They have fresh gloss black powder coat. I was going to use them to do a custom set up but changed directions. 70$ shipped in lower 48
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Re: FS Lower shock brackets. Fresh powdercoating
Open to offers and trades.
I can do 60 shipped....if someone is interested
Bump
Total
Open to offers
1st 40$ takes them shipped
![]() Join Date: Jul 2016
Are those for coil spring rear? Looks like the one on the right doesn't have a full hole for the shock to mount, can you verify with a better pic?
Yes they are for coil spring and they are complete. The white foam is covering that part. I'll try and get a better pic
Here you go randy.
Thanks Rob, I will go out and look at mine in the morning and see if I need them.
Bump !
Ttt
Bump
#15 |
![]() Join Date: Jun 2009
What did these come off of ? I have never seen this style
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#16 |
![]() Join Date: Sep 2007
i noticed that also and was wondering what these were out of?
1967custom |
#17 |
These are the first version 63 trailing arm mounts.
#18 |
I have a set of the same type on my truck...I have seen them in the past too and I think they are aftermarket and generally used with air shocks.
#19 |
Im pretty sure they are stock 63-66 brackets. Some people seek them becaus they can be drilled for a custom shock relocation. One thing for sure they are much stouter than the kind with a single bolt sticking out for the shock to ride on.
#20 |
I'll take 'em if they'll fit a stock coil sprung '72 2wd 1/2 ton, if they're still available.
#21 |
They are avaliable still. I know they should bolt to any trailing arm truck.
#22 |
Upper Shock Relocation 1963 through 1972 - The 1947 - Present Chevrolet & GMC Truck Message Board Network
http://67-72chevytrucks.com/vboard/s...d.php?t=451200 Here is a thread of a fellow doing some relocation you can see how they mount. Should work for stock or modified set up. I was going to to flip them side to side and run outboard shocks . But i could no due to very wide tires.
#23 |
good idea
1967custom |
#24 |
I'll take them if 46stude passes.
#25 |
PayPal sent.
My Cheyenne is stock height with worn out air shocks. I'm fixing to replace the shocks w/ a set of HiJackers & wasn't real fond of the factory single sided shock mount. These will remedy that problem. ![]() |
