Old 10-03-2016, 05:01 PM   #1
ubtripn
ubtripn's Avatar
Does this part go on a power
drum brake set-up? (I have been working on my brakes and this forum has been a huge help but this one question I just cannot find the answer to so I found a good pic.) I bought this exact MC and put the large end of the big rubber thimble shaped boot over the end of the MC where it mates to the booster. Does it belong there?
Thank you and I apologize for not being able to find the answer.
ubtripn is offline   Reply With Quote
Old 10-03-2016, 06:08 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Does this part go on a power
it loooks like the boot for the firewall where the rod goes thru to attatch to the pedal
1967custom
michael bustamante is offline   Reply With Quote
Old 10-03-2016, 07:01 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Does this part go on a power
Attachment 1577417
Yes it's a dust boot for the pedal rod from inside the cab.It keeps dirt out of the piston on the MC and water out of the truck so its a dual pupose gasket seal.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-03-2016, 07:31 PM   #4
ubtripn
ubtripn's Avatar
So it does go on the end of MC. Thank goodness!
Old 10-03-2016, 07:40 PM   #5
truckdude239
truckdude239's Avatar
It will not be used on the power brakes only on manual brake systems
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-03-2016, 08:43 PM   #6
Andy4639
Old member
Andy4639's Avatar
Correct sir it doesn't go on the MC if you are installing it on a booster, sorry I over looked that part. Its only when being used manually.
Old 10-03-2016, 10:27 PM   #7
ubtripn
ubtripn's Avatar
Yikes, ok thanks! That help explain a lot!
Old 10-03-2016, 11:32 PM   #8
RichardJ
Master with deep hole is for manual brakes and uses the dust boot.
CPP sells a master with deep hole and provide a spacer plug so that it can be used with a power booster. If you know what you are doing and have a lathe, you can make your own spacer. If not, return it for the correct master.
No matter what you do, the adjustable pin in the booster must be checked and adjusted to fit the master.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 10-04-2016, 12:13 AM   #9
VWNate1
VWNate1's Avatar
Question Re: Does this part go on a power
Nice ~ does anyone sell this tool ? .
I didn't see it @ Harbor Freight and spent far too long fooling with assorted adjustments .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 10-04-2016, 10:13 AM   #10
ubtripn
ubtripn's Avatar
Well I removed it and wow-what a difference, thank you all VERY much!
