Old 10-04-2016, 06:21 PM   #1
jondancer
4spd manual trans - 2wd version VS 4wd ?
It the stock 4wd 4spd manual trans different from the 2wd version.
jondancer is offline   Reply With Quote
Old 10-04-2016, 06:24 PM   #2
Mike C
Mike C's Avatar
Re: 4spd manual trans - 2wd version VS 4wd ?
Yes. Different main shaft depending on whether it was mounted to the transfer case or not.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-04-2016, 06:42 PM   #3
jondancer
Is that just bolt on?
Old 10-04-2016, 08:40 PM   #4
Mike C
Mike C's Avatar
No. It's the shaft that all of the gears are attached to. You must disassemble the trans, remove all the gears, bushings and synchros. Transfer to new main shaft and reassemble.
44 Willys MB
52 M38A1
64 Corvette Coupe
