10-06-2016, 10:09 AM | #176 | |
Re: No Limit Trailing Arm Rear Suspension
As far as ground clearance, w/a 5/7 drop one needs to become more aware of the roads they drive on for best results (minimal damages) depending on overall conditions where you live & just plain slow things down when traveling in unfamiliar areas. The usual point of contact is the front lower a-arm pivot points when there's an abrupt change in road surface @ speed.
10-06-2016, 10:47 AM | #177 |
That's kind of what I'm getting at:
"Designed to work with stock crossmembers" and "will not work with aftermarket crossmembers" are two different things. If it can be bolted on to a low profile one like porterbuilts,with its exhaust route already accounted for, I would rather install it that way. |
10-06-2016, 11:16 AM | #178 | |
1968 LWB C20 / AC / Wood Bed |
10-17-2016, 09:27 AM | #179 |
please be careful. Yes, our kit is designed to work with the OE crossmember. This was done to keep cost inline and keep the install easier. It DOES however include new front trailing arm mounts, designed to replace the OE mounts. The "Monster Ball" dimensions are NOT the same as the OE trailing arm bushing. So, the new mounts MUST be used. (or duplicated) If the custom crossmember your looking at has the trailing arm mounts welded on for the OE spec bushing, this will NOT fit the new trailing arm pivot ball. Since most crossmembers I have seen have welded mounts, I don't know of any that will be a direct swap. (please share information if you know of any) Knowing this, modifying the OE crossmember may work out best.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
10-17-2016, 09:50 AM | #180 |
FYI, the Early Classic Enterprises trailing arm crossmember does have the bolt-on mounts, Rob. But the crossmember is flat with one "ear" of the mount longer than the other to make up for the fact that the OEM crossmember is angled where the mounts attach.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
10-18-2016, 07:24 AM | #181 | |
I also have a Porterbuilt cross member on order to see which one I like better as far as fitment and exhaust pass through.
-1998 Formula WS6 1LE- LSX 427 4.58 @ 162 mph, 1.12 60' 2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels 1972 Chevrolet C10 Cheyenne - SOLD RaceWire Solutions |
10-18-2016, 08:11 AM | #182 | |
Let us know how your install goes! |
10-18-2016, 09:55 AM | #183 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-18-2016, 11:05 AM | #184 |
A question for Rob. I purchased the trailing arm kit for my 71 Blazer.
1: In your installation photos, you show two pan-hard bars connected to the bracket. Are there two? 2: The front trailing arm mount has two holes for the arm to attach. Which one do I use? 3: Should I remove the stock shock brackets from the frame? Thanks |
10-18-2016, 11:11 PM | #185 |
I think I have figured out question number one after going over the previous posts.
10-19-2016, 06:52 AM | #186 | ||||
10-19-2016, 10:26 AM | #187 |
Thanks for the response. I did remove the shock mounts. What am I looking for regarding rear end geometry? Am I trying to match pinion angle with transmission yoke angle?
10-20-2016, 09:09 AM | #188 |
Thanks for the help Scoti
11-16-2016, 03:46 PM | #189 | |
My 1970 c10 (550hp LSX, 4l80e, full Ridetech) http://67-72chevytrucks.com/vboard/s...d.php?t=556610 |
01-18-2017, 06:52 PM | #190 |
Sort of a weird project that I'd like to know if this could be made to work with.
I'm swapping my 51' Chevy body onto a 01' Silverado/sierra frame. I need to shorten the wheel base about 17" and want to ditch the leafs. If I was to get the PB crossmember and your kit, would I run into any frame width issues you think? I'm open to any other options you have as well. I saw you have a kit for the stock frame for my truck as well on your site. Would that be better? Thanks Posted via Mobile Device |
01-19-2017, 10:11 AM | #191 | |
Well, I won't say that this 'can't' be done, but I'm not sure I would advise this as a good idea. You could install a PB crossmember, but the front trailing arm mounts would need to be swapped for ours, not sure that is as easy as it sounds. And, that is the easy part. The rail shape of the '01 is not really conducive to the trailing arm suspension. More than that, I need to point out that a bigger concern may be width. The 47-54 Chevy's need a WMS (wheel mount surface) width of appx 58 1/2" to set down and fit a normal spaced wheel. The '01 WMS is close to 65" - I don't know for sure, that's web data, as I don't work on them, - you should measure. But this extra width will push the wheels outside the wheel openings and not let the truck sit down. If you want it 'up' that's OK, I guess. So you have this 01 chassis, which gives you front and rear suspension, rear axle, and eng/trans. Now, you have to shorten the frame, you want to change the rear suspension, the rear axle is too wide, and so is the front suspension, Also, I will take a guess that you will want to lower the front at some point. If your OE 3100 chassis is in good shape, start there. the body will fit correctly, and modifying the front/rear suspension will be easier. Just my $.02, Good Luck.
01-20-2017, 12:51 AM | #192 |
The width is something I wanted. I know this is the reason people stay away from these frames but I'm planning to radius the fenders for clearance. Seen one truck with it done and I like the look. I don't have the original chassis and the other reason I'm doing it this way is to use the wiring from the sierra to transplant into the other truck. I can't shorten the frame as there's not enough from under the cab to shorten what needs to be taken out. I've thought about 4 link and 3 link setups as well but I've been threw your make it handle thread a few times and like this style. So if I were to just use your kit for the 47-54, besides track width, would it be close enough to work with. The part I'm thinking is going to be an issue would be the coilover mounts. Thanks again. Once again if you have something else that would be simpler I'm open to it. Posted via Mobile Device |
01-27-2017, 10:44 AM | #193 |
Mỹ project is going together, and got spacers made to run the No Limit Trailing arms with the Porterbuilt Boxed inner stiffener. These are made out of steel plate on a CNC machine.
-1998 Formula WS6 1LE- LSX 427 4.58 @ 162 mph, 1.12 60' 2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels 1972 Chevrolet C10 Cheyenne - SOLD RaceWire Solutions Last edited by SMKN TA 95; 01-27-2017 at 11:15 AM. |
01-27-2017, 11:24 AM | #194 |
Nicely done.
01-28-2017, 04:19 PM | #195 | |
Adam B
Would you be willing to post where you had these made or information about them. I will we willing to buy two of these for my future build. |
02-08-2017, 10:21 PM | #196 | |
I second that. I have just installed the porter built crossmember and was thinking is upgrading to the no limit trailing arm kit
02-10-2017, 05:19 PM | #197 |
So in one of the posts it sounds like you cannot use original drum brakes due to parking brake cable routing issues. Is that correct or did I miss something? Being bolt on is great but if I then have to swap to disk brakes that would make me second guess.
02-10-2017, 06:50 PM | #198 |
No you can use OEM drum brakes with this kit, what was asked was why is there was no bracket ( Tab) to hold the parking brake cable to the No Limit trailing arm so the cable can be routed along the trailing arm Like the OEM trailing arm ,
02-10-2017, 08:02 PM | #199 |
Ok, I thought one of the post's mentioned that the coil-over was in the way of the cable routing.
02-17-2017, 11:55 PM | #200 |
Rob..... 2 questions for you:
1) Was there a reason you chose the sleeve mounting arrangement top & bottom vs a dbl shear bracket set-up? 2) What is the angle on the C/O's? I'm curious is it looks close to what my shocks have & I was worried about angles impacting their performance. Didn't know if its just as important w/the C/O arrangement.
