Old 10-06-2016, 03:22 PM   #1
jbgroby
jbgroby's Avatar
Inside door latch handle issues
Anyone have problems getting the inside door handle latch to engage the door lock? I can't seem to get the door handle to release the lock?
Thoughts?
jbgroby is offline   Reply With Quote
Old 10-07-2016, 01:08 PM   #2
61K10
61K10's Avatar
Re: Inside door latch handle issues
doesn't the key just lock the button? Inside handle locks the linkage.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-07-2016, 01:41 PM   #3
jbgroby
jbgroby's Avatar
With everything installed correctly, I can get neither side to open the doors from the inside, I'm thinking the new parts are off. I 'll try to post pictures this weekend.
Old 10-08-2016, 06:30 PM   #4
63burban
Chevy addict
There is some adjustment needed on the handle relay. The part the handle mounts to can be adjusted so both lock and release function work properly, it doesn't take much at all.
63burban is offline   Reply With Quote
Old 10-09-2016, 08:08 PM   #5
jbgroby
jbgroby's Avatar
Thanks, but I'll grab an OEM one, send these to the island of Mis-fit parts......
Old 10-10-2016, 09:40 AM   #6
jbgroby
jbgroby's Avatar
Ok,we think we figured out what the problem is. The OEM door release is operated by a spring and moves the linkage forward and backward. The NEW aftermarket setup DOES NOT move the linkage forward enough to trip the release spring on the door lock. I had one OEM linkage for the passenger side and it works perfectly.
Side by side they are identical, but the spring just does not work correctly. It's possible that the springs is just too hard/tight, but you are taking a chance of striping the teeth off of the new shaft part (trashy soft metal). I see now way to adjust the spring.
I reached out to RJ Sisneros in Colorado for a OEM linkage.
http://i1299.photobucket.com/albums/...psqagr1wjl.jpg
Jake
Old 10-10-2016, 12:31 PM   #7
61K10
61K10's Avatar
send them back--
1961 chevy K10
Old 10-10-2016, 01:51 PM   #8
jbgroby
jbgroby's Avatar
Bought too long ago, over 3 years. not worth even passing them on.
