10-07-2016, 10:39 PM | #1 |
Welding gas?
I have a snap-on mm250 welder, its a mig with tig capabilities, I bought the tig kit with it 10 years ago but haven't used it, just used the mig. I want to try the tig but I don't want to have to buy another gas bottle and have to keep switching bottles when switching from mig to tig. is there a gas I can use for both? This will be used for welding steel only as the welder is not ac/dc capable.
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
10-07-2016, 10:44 PM | #2 |
Re: Welding gas?
Common mixes for mig are c25 or c15, tig on the other hand needs 100% argon. So unfortunately you will need to get a second bottle
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
10-07-2016, 11:15 PM | #3 |
Re: Welding gas?
I'd ask is can the 100% Argon be used for MIG? My guess is yes, but the cost may be higher.
10-07-2016, 11:21 PM | #4 |
Re: Welding gas?
You could mig weld steel with 100 argon but I don't think it will turn out very well, at least it didn't when I tried it. One possible solution is to have one bottle of 100 argon for tig and then use flux core for mig so no gas is required
10-07-2016, 11:32 PM | #5 |
Hollister Road Co.
Re: Welding gas?
Straight Argon for mig welding steel does not work because its to cold
C25 for tig does not work because its to hot. |
10-07-2016, 11:34 PM | #6 |
60-66 Nut
Re: Welding gas?
You will need 2 separate shielding gases for MIG and TIG. I use 75/25 for MIG and pure Argon for TIG.
10-08-2016, 06:47 AM | #7 |
Re: Welding gas?
Unfortunately, you will need two different bottles. Mig needs co2, without it mig gets pretty temperamental. And just try and tig with anything other than 100% argon and that is pretty much a disaster so yea.
10-08-2016, 03:36 PM | #8 |
Re: Welding gas?
Well, at least everyone agrees. Thanks guys!
10-08-2016, 04:06 PM | #9 |
Re: Welding gas?
I live in Houston and Manage 4 Praxair locations here in Houston.
They are correct on the Shielding Gases. Question is there a local Praxair in your area? If there is send me a private message.
Rincon |
10-09-2016, 12:28 AM | #10 |
Re: Welding gas?
No local Praxair.
