Old 08-16-2016, 08:24 AM   #1
robozride
Nina Patina 1953 3100 project.
Hey there good truck people. I picked up my latest project this weekend and will spend the next few months making "Nina" a happy girl. This old truck has a pretty good story.. A fellow in Missouri bought it new and used it for his plumbing business until he retired. Upon his death his daughter took ownership of the truck and stored her for the next 25 years (yes, a real barn find). That's when I purchased her from the original owners daughter and dragged her home. I will be leaving the exterior as is with cleaning only. New MII ifs with power rack in the front and 4 bar with coil overs in the rear. Motor will be sbc normally aspirated with an automatic trans. Ill change the steering column, seat, shifter, gauges, etc and will probably paint the inside of the cab to make it more comfortable. That's about it, she will be stereotypically low with 18's and ready to pile on some new stories.
robozride is offline   Reply With Quote
Old 08-16-2016, 08:28 AM   #2
robozride
Re: Nina Patina 1953 3100 project.
So the first thing I did was order all of the needed suspension parts so we could get started in a couple weeks.
Last night I decide Nina deserved a long overdo bath. I broke out the power washer and a spray bottle of CLR and here are the results, I cant believe how much color was hiding under all of the oxidation!
Old 08-16-2016, 12:11 PM   #3
Advanced Design
Advanced Design's Avatar
Sounds cool. I am in for the ride along....
Advanced Design is offline   Reply With Quote
Old 09-11-2016, 05:20 PM   #4
robozride
And... Were off! started tare down today. No surprises lotsa dirt grease and broken bolts. Things are looking pretty solid though.
Old 09-11-2016, 06:30 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks like an amazing start!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-13-2016, 08:19 PM   #6
robozride
60 year old Missouri dirt up in there
Old 09-16-2016, 12:16 AM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Your truck is in amazing condition considering how it was stored. Looking forward to seeing the transformation.
Zoomin is offline   Reply With Quote
Old 09-19-2016, 10:54 PM   #8
HUSSEY
HUSSEY's Avatar
Great looking truck. How did it look after it dried out with the CLR bath? Before I finished reading your first post I though to myself, please Lord don't let there be another clear coated patina truck. Glad to see you're leaving it AS IS.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 09-20-2016, 08:11 AM   #9
robozride
Ill post some pictures of the after when I start to reassemble. IT came out really good, brought out a lot of the color that you couldn't see and took all of the rusty "haze" off so it gives it a good contrast. I was worried about it looking wet sanded or scratched up so I didn't go crazy with the arm pressure and it looks pretty good. NO! No clear coat for me!
Old 09-20-2016, 08:17 AM   #10
robozride
Rear frame is stripped an ready for four link.
Old 09-20-2016, 08:28 AM   #11
STOCKISH
STOCKISH's Avatar
Nice, Keep it up! Whose 4 link are you going with?
--Josh
Old 09-20-2016, 09:36 AM   #12
robozride
Its a Speedway kit for 47-54
that comes with bolt/weld in brackets, bars and shock cross mount. Ill be adding some plating and small c-notches as well.
Old 09-20-2016, 04:09 PM   #13
STOCKISH
STOCKISH's Avatar
I am debating on using that same kit. Be sure to post plenty of pics!
--Josh
Old 09-20-2016, 10:38 PM   #14
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice Patina!
ChuckDriver is offline   Reply With Quote
Old 10-09-2016, 01:22 PM   #15
robozride
So I had a couple days off and installed the rear Speedway four link and a c-notch. The kit installed pretty easy and as you would expect. The low bars bolt on for reference and then the others line off of those. Your supposed to drill for the other bar mounts and shock cross member, but I welded it all in. The only complaints I have are that the instructions are a little vague, but easy enough if you have any experience. Also all of the bolts are big 5/8 fine thread with nylocks and mine came with coarse thread nuts? not easy to find most places. I think in the end I will need to go with shorter shocks or rework the mounts to get it as low as im looking for but wont do either till I get all of the weight back on it.
Old 10-09-2016, 07:13 PM   #16
DeanTX
DeanTX's Avatar
Looks like a nice 4 link kit. Wheels look good too.
DeanTX is offline   Reply With Quote
Old 10-09-2016, 08:29 PM   #17
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What axle are you using and how do the bars attach to it?
Old 10-11-2016, 08:00 AM   #18
robozride
Its a 69 Camaro 10 bolt. The brackets upper and lower are welded on.
Old 10-11-2016, 06:04 PM   #19
lower50's
lower50's's Avatar
So cool you basically bought it from the original owner. Are there any holes in the body at all?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-11-2016, 07:39 PM   #20
robozride
Yep, it has the guys name and town with aluminum plated letters on the drivers bed side, he used it for a plumbing business. One hole about the size of a 50 cent piece in the passengers cab corner, other than that very solid.
Old 10-11-2016, 07:53 PM   #21
robozride
Not a clear photo but here's what I was referring to. Has his name and Higginsville Missouri and the zip, I plan to leave it there, originally had some orange lettering on the door for his business but only little spots remain, not legible at all.
Old 10-11-2016, 08:34 PM   #22
mongocanfly
mongocanfly's Avatar
Good looking truck ya got there..what brand tires are those?
Old 10-16-2016, 01:52 PM   #23
robozride
Front end is striped and ready to star mockup.
Old 10-22-2016, 03:43 PM   #24
robozride
CPP kit fits and installs well. Back on 4 wheels tomorrow!
Old 10-22-2016, 04:38 PM   #25
joedoh
joedoh's Avatar
what a great start!
