10-20-2016, 02:17 PM | #1 |
Share your steering box wisdom.
Ok, so the old 1965 C10's manual steering box has about 7 inches of play that won't adjust out. Oddly, the rest of the front end parts are pretty decent.
The box has a lash adjuster on it, which I tried 1/4 turn at at time, and it worked for about 20 miles, but now it looks like the shaft that the pitman are is attached to is actually moving downward, coming out the bottom in other words. WTF? So, rebuild kit? Reman box? Not super interested in a power steering setup. Thanks in advance. |
10-20-2016, 05:24 PM | #2 |
Moderator
Re: Share your steering box wisdom.
I'd remove that old box, put it in my wife's truck and take it to orielly and get a new one. Whats the question again?
10-21-2016, 11:39 AM | #3 |
Never Ending Projects
Problem is, most places don't list nor can get a manual steering box. Orielly's, Autozone and NAPA do not list them.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-21-2016, 12:02 PM | #4 |
red hat steering gears did mine. Great people to deal with and 100% warranty. All you have to do is install the unit.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-21-2016, 03:27 PM | #5 |
Mine was so bad that when I poured gear oil into it there was a noticeable drip drip as it tried to empty it self. Darn steering wheel was also pretty well gone because it was so hard to turn.
A 67 PS box and an adapter plate for mounting it was all that was needed. Of course after a collapsible shaft and fabricated pump mounting bracket the story gets longer. |
10-21-2016, 05:44 PM | #6 |
You guys had good luck with Rockauto?
10-21-2016, 07:09 PM | #7 |
I've bought a new dual master cylinder and brake wheel cylinders from Rockauto. I never had a problem with any of it but if I was replacing a steering gear I would at least look into the Red Hat option.
10-21-2016, 09:41 PM | #8 |
Moderator
Or Red Head.
