Old 10-20-2016, 09:21 PM   #1
novice
Moog lower ball joint question. Need Help
I have new Moog ball joints. I pressed the lower one in my factor control arm with no issue. My question is about the rubber grease seal. The directions are not very clear for me. I was wondering if the rubber seal slid over the larger portion of the ball joint shaft or if it just butts up to the shoulder. It seems to small to slide over the shoulder. I'm wondering if it just butts up to the shoulder and the installation of the spindle keeps pressure against it so grease doesn't just come out. Any help is greatly appreciated.
novice is offline   Reply With Quote
Old 10-20-2016, 09:29 PM   #2
freak
Re: Moog lower ball joint question. Need Help
You'll never find a ball joint boot that fits like the oem ones. Most times they just end up floating on top with pressure from the spindle like you say.
freak is offline   Reply With Quote
Old 10-20-2016, 09:34 PM   #3
novice
Okay. So that is "normal" so to speak? They function okay like that? My fingers hurt from mashing on these stinking things and my throat is tired of cussing. I mash them down, get one side on, and press on the other side and it pops off.
Old 10-20-2016, 09:35 PM   #4
freak
Not good but normal I guess.
Old 10-20-2016, 09:39 PM   #5
novice
Thanks freak. I appreciate your input. I've been stumped for an hour.
Old 10-20-2016, 09:54 PM   #6
Boog
laying low
Boog's Avatar
That boot has to slip over the outer ball joint to seal dirt and water out. It is a real snug fit but it will slip over.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-20-2016, 10:06 PM   #7
novice
Thanks Boog. I guess the cussing will commence until I get these things installed correctly..
Old 10-21-2016, 03:00 PM   #8
novice
Just as a follow up, I called Moog today and the rubber seal is suppose to push down over the shoulder as mentioned above. I feel like a lot of bad words is coming from me in the near future.
Old 10-21-2016, 03:01 PM   #9
freak
We all know it is supposed to. Getting it there is a whole other story.
Old 10-21-2016, 03:02 PM   #10
95 S_Trucker
95 S_Trucker's Avatar
It usually takes me a few minutes and 2 pairs of channel locks to seat the boot. You'll get it on there.
95 S_Trucker is offline   Reply With Quote
Old 10-21-2016, 03:07 PM   #11
novice
I'm a little slow. I wasn't sure if it was just a friction type seal or if it actually slid over the shoulder itself.
I'm going to have to try the double channel lock idea.
Old 10-21-2016, 04:01 PM   #12
randy500
They way to do it is find a piece of pipe with an ID that matches the reinforced boot and drive it over with a mallet.
randy500 is offline   Reply With Quote
