17 inch rallys??
Anyone running the 17 inch rallys on a 66 style truck? Ive been thinking about it and tire size options?? Thanks for any info you can provide.
Re: 17 inch rallys??
Check out the ALUMINUM Rallys at Year One!
Well, what tire are you running now? What are your plans to do with truck? Towing? Assuming a 235/75/15 = 28.8" and a 235/55/17 =28.1" start there. Goto a tire store or look on line for brand, load capacity, and other sizes.
I run 245/45/18 front and 295/45/18 rear. 26.6 and 28.6" tall.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
What are you running for rear shocks? Maybe a set of 'progressives' would help during tow trips. Looks like fleeBay has some wheels; lmc is no help.
1969 ES5500 B E A S T 1976 K20 Suburban 1983 C10 'farm truck' 1984 K10 Suburban 1988 V30 Fire Truck 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
Monroe just for mock up on the rear. Any pictures of 17 inch wheels on our trucks guys?
![]() Join Date: Aug 2014
I am also tossing around the idea of trying a set of the new rallys. Im looking into the 18s though.. Just wanna do staggered and cant find a tire size I like yet. Guess Im picky..
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
These are 18x8 and 18x9 with 245 45 18 front and 285 45 18 rear. I was going with a 295 45 18 for the rear but found an amazing closeout deal on a pair of Pirelli's 285 45 so I'm going to run them for a while.
#9 | |
Can you tell us who makes the wheels and what BS you have? |
17x8
4.5 front/5 rear drop with 275/55R17 in the rear and 275/50R17 up front Last edited by forestb; 10-24-2016 at 04:25 PM. |
Yep im liking what im seeing!!!!!
Verdel how much is your truck dropped? I like a lot! I love the thoughts of 285s out back. Did you have to modify anything else?
Be careful when buying 17's the tires are much more expensive than 16's or 18's because it is a rair size.
#15 |
I have 2.5" drop spindles up front with the torsion bars cranked down a little but not sure the exact measurement. I simply adjusted them to the height I wanted. Same thing for the rear air bags. No modification was needed at all. I actually run it a little lower than the height on the pics...hope this helps
#16 | |
#17 |
Anyone else care to share there big rally wheels??
