Closed Thread
Old 10-22-2016, 05:37 PM   #4526
San Diego Ron
San Diego Ron's Avatar
Re: What did you do to your truck today? Chapter II
Mine is back together after back yard paint job, just need to clean it up a bit.
San Diego Ron is offline
Old 10-22-2016, 07:24 PM   #4527
rsgt
rsgt's Avatar
Looks good!
rsgt is offline
Old 10-22-2016, 08:28 PM   #4528
71threequarterton
71threequarterton's Avatar
Pulled the bench out. The truck came with pretty nice looking re-upholstered tan interior but the seat is worn through on the driver's side and the PO had it covered up with some cheap Chinese seat cover that I didn't like at all.
I bought a black "Dorchester" cover from Seat Covers Unlimited - supposedly really durable for heavy duty use and Made in USA! It fits nicely and looks good.
While I had the seat out I cleaned out the cab with a shop vac and fixed the 3 pt. seat belts - whoever installed them had them flipped over the wrong way so in order to fasten them you'd have to twist them over and they'd be all bunched up and ride up on your belly - super annoying and uncomfortable! I fixed that problem by pulling off the retractable units where they anchor to the floor by the door jamb so I could flip over the belts and bolt 'em back down the right way.
Taking the bench out and putting it back in was pretty easy. I used some cardboard under the driver's side legs so I could slide it out and back into the cab and had a coleman cooler outside the passenger side to rest it on while I maneuvered it out and back in(first time I've used a cooler for something other than beer ).
The hardest thing about it was lining up the holes when I reinstalled the bench. Even with one front bolt in on each side, the back legs didn't want to line up.
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
71threequarterton is offline
Old 10-23-2016, 07:51 AM   #4529
BugzC10
BugzC10's Avatar
Gave the girls a bath
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-23-2016, 09:09 AM   #4530
lots-o-bunnys
My truck build has come a long way in the last few months, yesterday i put my 12 to 10 bolt fuel pump adapter in. I have a rear mounted boyd welding fuel tank with a single 340 pump. I ditched the single 340 pump and went with a aeromotive phantom dual 340 pumps. I plumbed the pumps from 2 -6 lines into one -8 hose with a backflow preventer.
To see more details of this build check out 71k10restomod build
http://67-72chevytrucks.com/vboard/s....php?p=7747656
lots-o-bunnys is offline
Old 10-23-2016, 10:50 AM   #4531
Ekliptix
Ekliptix's Avatar
Heated up the tires. https://youtu.be/An3NhSvO9-M
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 10-23-2016, 12:59 PM   #4532
Nhoechst
Nhoechst's Avatar
Well over a few days I lowered it, put new shocks, ball joints, tie rods, brakes, and headers on it. Did 2.5 drop spindles up front and 4 inch lowering springs in the back. Pretty happy with it but may do an inch lower up front with smaller springs if it doesn't settle any more. Can't complain though, first time working on it all year because I've been slammed at work and it went great. I'm on here all the time while traveling to tracks and love watching yalls projects, makes the time go by quicker! In the winter she'll get a new torque converter, wiring harness, lights, and straight pipes.
1972 C10, used to be daily driven and hoping to be that way again at some point.
Nhoechst is offline
Old 10-23-2016, 02:26 PM   #4533
Steeveedee
Who Changed This?
Steeveedee's Avatar
Saturday, took my truck to the storage yard and picked up my new trailer. First time it's been attached. Took the trailer home and installed "poles" in two cabinets for clothes on hangers. Wife put in the dog beds, etc.
Sunday, put in a new heater/AC blower switch. Got it from LMC. Also ordered 3-point seat belts and a new lap belt for the center passenger. I'll put those in, a little after lunch. 4 days to deliver, and the parts are correct.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 10-23-2016, 03:49 PM   #4534
66clow
66clow's Avatar
Blocked my fender and painted the cowl panel. Fixed a ignition switch wire that I must of knock loose at some point and caused my battery not to charge. Had to jump start it to get home. Hate that when things go wrong after you done fixed it. Glad I knew where to look.
66clow is offline
Old 10-23-2016, 03:58 PM   #4535
66clow
66clow's Avatar
Got to keep them tires maintained by regularly heating them up. Nice!
66clow is offline
Old 10-23-2016, 09:12 PM   #4536
CaptainMorgan_SOS
Replaced the front fender. The old one was pretty beat up, had about 4 snapped off bolts in it, and was pretty much held on by sheetmetal screws that one of the previous owners threw in there.
CaptainMorgan_SOS is offline
Old 10-25-2016, 07:14 PM   #4537
Toms67
Toms67's Avatar
Getting firewall ready for paint.
Toms67 is offline
Old 10-25-2016, 08:28 PM   #4538
saxart
saxart's Avatar
Called the DMV to ask where my title is after waiting 10.5 weeks. I hear the lady on the other end of the line typing on her computer. "Um.. It looks like it was done awhile back, but for some reason never got sent out in an envelope. Sorry, I'll do that for you now..."
Grrr.....
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline
Old 10-25-2016, 11:30 PM   #4539
74baggedbug
Got rid of the old gauge
74baggedbug is offline
Old 10-26-2016, 11:07 AM   #4540
73737373
Originally Posted by SoCoC10 View Post
LOTS of masking. Used my rear bumper's box to make a 2" "window" in 4ft section. Only masked the upper and lower with the expensive/good tape then used cheap tape/duct to join the window to the good tape. Painted with my touch up gun with Rustoleum 4 parts flat to 1 part gloss 1 part acetone. Key is to use a flat surface (like a paint stick in my case)and wrap paper tight around it. Wet with acetone and use even pressure to expose to two shiny high ridges. Tedious but worth the effort.
I have used semi-gloss black pin striping tape on these and the lower moldings. Much more forgiving than paint.
73737373 is offline
Old 10-26-2016, 11:23 AM   #4541
matthamby
Hey guys, been trolling around, found this site that may be interesting to some of you.
http://bluewireautomotive.com/
matthamby is offline
Old 10-26-2016, 12:05 PM   #4542
VWNate1
VWNate1's Avatar
! WARNING ! never, EVER click on any link that isn't clearly described ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-26-2016, 12:45 PM   #4543
matthamby
Hey, sorry about that, I was looking for certain things, lights gauges, etc... found an eBay listing that had lights from this company, I searched the company up and went to their web site. That is a link to their site. Lots of cool stuff for lots of different applications - dash lights, warning lights, etc... The link is clean, at least it was when I made it!
Old 10-26-2016, 02:33 PM   #4544
mrcomedy104
mrcomedy104 is offline
Old 10-26-2016, 02:35 PM   #4545
mrcomedy104
I'm currently swapping the motor on my c20, I've never done this but I have the motor in the transmission, it's not going in all the way, would someone be able to help resolve this?
Old 10-26-2016, 06:42 PM   #4546
San Diego Ron
My truck is back in business after repairs and paint...finally!
Old 10-26-2016, 07:55 PM   #4547
flashed
Looks great .
flashed is offline
Old 10-27-2016, 08:46 AM   #4548
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today? Chapter II
?? Do you mean the engine and tranny don't quite close up the gap ?? .
If so, 99 % of the time the Torque Converter isn't quite properly settled in on all three of it's splines.....
-Nate
Geezer
VWNate1 is offline
Old 10-27-2016, 09:40 AM   #4549
un4gvn!
un4gvn!'s Avatar
Make sure the pilot bearing was removed from the back of the crank shaft if it had a standard transmission. Spin and push in the torque converter until you feel three clicks. Bolt the trans to the motor before you bolt the converter to the flex plate. The converter and the flex plate should have 1/2 to 3/4 inch gap between them. You should have to pull the converter out towards the flex plate to eliminate the gap.
un4gvn! is offline
Old 10-27-2016, 10:02 AM   #4550
VWNate1
VWNate1's Avatar
" You should have to pull the converter out towards the flex plate to eliminate the gap. "
THIS !~ if you cannot easily spin the Torque Converted by one finger when the engine is mated to the bell housing , the T.C. likely isn't properly settled .
-Nate
Geezer
VWNate1 is offline
Closed Thread
