10-22-2016, 07:41 PM | #1 |
Center Link & Tie Rod Ends
I have been gathering up all the steering parts that I need to re build my Trucks steering frame stuff. My trucks PO's had installed 92 C10 Spindles & Disc Brakes for an up grade but looking at it a little closer and Driving it the Mod's aren't right in many ways so I went and found another Center link that just happened to have all the old ends on it and was measuring it and was also measuring mine to make sure I will have it some what close to being Aligned. The Tie Rod end threaded part that go into the Adjusting Sleeves are a little thicker than the New ones I bought, both of the two my existing one on the truck and also the one I went out and bought. I used my non Digital Calipers and measured both (used ones) and both are the same around .676 just under 11/16". The New one is a Moog part and it measures .625 5/8". So all that said WTF's going on with this. I have looked at 4WD that has a different Tie Rod and the 2WD 1/2 & 3/4 tons are No different same size 5/8". My truck is a 68 C10 LWB, originally had a I6 & Manuel Steering. Sorry for being long winded. Any help would be great, Thanks
10-22-2016, 09:02 PM | #2 |
Re: Center Link & Tie Rod Ends
This may help or not, 87 was used on a 66. 66 is same as 67-70.
http://67-72chevytrucks.com/vboard/s...d.php?t=168486 and another http://67-72chevytrucks.com/vboard/s...ng+center+link
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 10-22-2016 at 09:24 PM. |
10-22-2016, 10:30 PM | #3 |
I'm going thru this right now also.. get 72 c10 outter tire rods but make sure they give you the 11/16 not the 5/8.. also your gonna need to use some 63-70 outter tierods for your inner tire rods
10-22-2016, 10:37 PM | #4 |
67-72 parts collector,…
5/8" tie tods are for 63-70 trucks.
The 71-72 and 73-87 trucks use the 11/16" tie rods but they are threaded the opposite direction of the 63-70 versions. I don't understand why everyone is trying to reinvent the wheel. Disc conversions are simple and straight forward if you use the correct parts. Quit trying to use 88-98 spindles with the 63-87 a-arm geometry.
10-23-2016, 07:11 AM | #5 | |
10-23-2016, 04:02 PM | #6 | |
So to use oem 1970 steering parts you need CONVERSION spindles to work with your current parts. These spindles are available EVERYWHERE in drop and stock heights for around $230. The aftermarket has made it easy to add disc brakes to 1963-70 drum brake trucks. No need to mix and match parts anymore. BUT if you must use some 40+ Year old junk yard spindles. Match your steering components to them. So you will be buying 71-72 parts or you will be buying 73-87 parts. I tried to spell out every possible scenario in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444823 I'm an old guy trying to save you guys all the headaches I went thru in the 1980's when all these cool parts weren't available. Conversion spindles! 71-87 rotors bearings and calipers. 71-72 master cylinder and prop valve Bend a few steel lines. Done!
10-23-2016, 04:06 PM | #7 |
Conversion spindles,...
https://www.summitracing.com/search/...tOrder=Default
10-23-2016, 04:27 PM | #8 |
Edit:
Via pm I find out the op wants to keep DRUM brakes. Disreguard my disc brake info. Sorry for the confusion.
10-24-2016, 05:30 PM | #9 | |
