10-24-2016, 01:44 PM | #126 | |
Re: Putting Camaro front in 55 second gen
Another couple pics! A good comparison from the day I drug it home, last day of March.... Last edited by Dave0; 10-24-2016 at 01:54 PM. |
10-24-2016, 05:13 PM | #127 |
Those look like typical 50s door gaps.
Takes a ton of work to get them all even. Kim |
10-24-2016, 05:56 PM | #128 |
10-25-2016, 02:04 AM | #129 |
Just took the time to look through your build again and just had to comment this time.
Serious fabrication skills all around. Nice work! |
10-25-2016, 04:05 PM | #130 | |
Nothing to ground breaking, just a whole lot of planning and work... All this fits under the stock bed floor, one of my wants going into it, I wanted to keep it at stock level. |
11-03-2016, 04:23 PM | #131 |
DaveO, Thanks for the advise on the Lokar shifter. I purchased one off Evil Bay and it bolted right up, very Simple. Now I'm trying to hook up my steering shaft and need to know what u joint you used. I noticed it in your pic of the trans linkage (BLACK U JOINT). I have a GM column and firebird frontend like you.
I've got a lot of great ideas from you! thanks' IN ADVANCE. |
11-03-2016, 06:57 PM | #132 |
Mine is a mid 70 camaro column and 70s camaro box and shaft. Do your homework, count splines and measure shaft. This one worked for me...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
11-03-2016, 07:21 PM | #133 |
Thanks for the education. Your the man!
Your truck is coming along great. I like checking in and seeing your progress. Your just a couple steps ahead of me. |
11-11-2016, 06:14 PM | #134 |
Slid the frame out from under the cab today. After taking all the suspension off...Worked out pretty slick!
Getting serious now, I need to get the frame all welded up before Wed, then off to be blasted along with the cab.... Anyone recommend some camaro tubular A-arms? I dont want China junk... |
11-12-2016, 12:11 AM | #135 |
I used these guys stuff on my Chevelle clip.
Very nice quality parts. Easy to deal with and very knowledgeable. They have different sets depending on what year Camaro you have. http://scandc.com/new/catalog/12 These are mine. Kim |
11-17-2016, 08:13 PM | #136 |
Damn, those things are pricey!
Blasted the frame, rear end and all suspension components... Frame is in the booth! |
11-17-2016, 09:29 PM | #137 |
That looks great. I have just wiped my frame down once more and hope to be priming in the next couple of days. Hoping for it to warm up a bit first.
I am spraying Eastwood epoxy primer then their ceramic chassis coating. Just about all the small parts are disassembled and ready also. |
11-17-2016, 10:15 PM | #138 |
I am anxious to see this finished, good looking project
11-18-2016, 04:35 PM | #139 |
And so it begins.... Again!
11-18-2016, 06:41 PM | #140 |
Looks real nice.
Kim |
11-19-2016, 05:35 AM | #141 |
A320 Pilot/USAF Retired
Slick!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
11-25-2016, 07:58 PM | #142 |
Looks great so far!
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
12-01-2016, 10:58 PM | #143 |
Back at home on stands....Collecting bolts, painting brackets and bolts. LOL
12-01-2016, 11:39 PM | #144 |
Atta boy Dave0!!! Looks really awesome! How did you get another inch or two lower? I like the way she sits. I hope mine looks that good.
12-02-2016, 12:44 AM | #145 |
Looking real good.
Kim |
12-02-2016, 08:47 AM | #146 |
12-10-2016, 11:42 PM | #147 |
The only reason you need not to buy china fittings, These are both -6 an, which one would you rather have feeding your fuel lines....
12-24-2016, 09:19 PM | #148 |
Tank in, rear end mounted, front suspension together, spent the last 2 hours power washing the engine.... As soon as I get the oil pan modified, its going in!
12-25-2016, 10:46 AM | #149 |
Looking good.
Kim |
12-25-2016, 02:42 PM | #150 |
Looking really good - you are knocking this thing out!~ its goes pretty quick once you have all the parts and everything painted. I used the QA-1 front parts on my Camaro clip. Mines about where you are now too.
Keep it up!
My Build: 57 Chevy Pro-Street |
