Old 10-24-2016, 09:14 AM   #1
Deer_hunter_088
Deer_hunter_088's Avatar
So i found stuff.
So i finally decided to try reading the SPID sheet, and found out that my truck is a 350 v8 truck with a turbo 400 trans, power brakes, ac, power steering, was white, had a blue interior, and this is what it has right now. but its on a 73-87 frame, but it looks like the original motor/ transmission. but my truck has been restored before, but i think it may be numbers matching.
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 10-24-2016, 09:31 AM   #2
geezer#99
geezer#99's Avatar
Re: So i found stuff.
Kinda hard to be 'numbers matching' if the frame is different.
THere are vin numbers on the frame you know.
geezer#99 is online now   Reply With Quote
Old 10-24-2016, 09:47 AM   #3
Deer_hunter_088
I know that i mean motor/ trans. which gives me some worries. if its a 47 year old trans, then there is a chance its worn out, the motor is pretty fresh looking so im not worried about that. if the trans is junk im throwing a 5 speed in it.
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
Old 10-24-2016, 10:05 AM   #4
geezer#99
geezer#99's Avatar
What's the casting codes, date codes and suffix codes on your motor?
Old 10-24-2016, 10:22 AM   #5
Deer_hunter_088
Il look at that tonight if i remember, its lifted so doing anything in the engine bay is a PIA and makes me become a human pretzel. but underside repairs are easy, who needs a jack
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
Old 10-24-2016, 10:32 AM   #6
LongBox
How can you tell from the SPID sheet that the trans is a TH400? My SPID just lists M49 Turbo-Hydramatic, and it turns out to be a TH-350.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-24-2016, 10:40 AM   #7
geezer#99
geezer#99's Avatar
Turbo 400 is rpo code m40.
Old 10-24-2016, 10:45 AM   #8
Deer_hunter_088
hmmm il check when i get home, but i know its a 400 trans.
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
Old 10-24-2016, 06:11 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
your truck was born 2 wheel drive and converted to 4x4 am I correct? The 2 wheel 400 and 4 wheel 400 are different and short of a divorced transfer case a 2 wheel trans won't work in a 4x4. So if your truck is converted to 4x4 than that means it's not the original trans... Also no 67-72 4x4 auto ever came from the factory with a th400, all 4x4 autos were th350.
Tyler
Old 10-24-2016, 06:16 PM   #10
Deer_hunter_088
Did the 73-87s come with a th400?
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
Old 10-24-2016, 06:22 PM   #11
kwmech
The 400 2wd had the same output shaft as the 4x4 for the 205 t-case, and can be easily swapped with just the adapter. 203 t-case took a shorter output, and the 241/208 combo had a different length also
Old 10-24-2016, 08:08 PM   #12
52napco
The only way to utilize a 2wd 400 is with a custom adapter from advance adapters etc.
The out is 32 spline but is longer than a 4wd shaft.the 400/205 is very hard to find but
I do have a few laying around but have sold hundreds over the years to ORD.
52napco is offline   Reply With Quote
Old 10-24-2016, 08:11 PM   #13
52napco
Had a brain fart and had t350 on the brain sooo the 400 short 2wd is the same.lenght
Oops 😅😅
Old 10-24-2016, 10:13 PM   #14
kwmech
Wrong, factory 2wd and 4wd, (205) both have the same 4-1/2'' stick-out from the back of the trans. The only difference is the 2wd is normally threaded for the bolt on yoke.
http://67-72chevytrucks.com/vboard/s...d.php?t=637778
