Old 10-25-2016, 09:49 AM   #1
vikingsandpintos
Junior Member
67 grill inserts?
I have been looking at the catalogs, and am not seeing grill inserts listed anywhere. I see the large grill frame, and the insert trim, ect... But no inserts.
I have looked thru the forum, and it sounds like they are riveted on. I haven't pulled the trim off yet to look. The previous owner had painted them a gray color, and I'm not sure if they didn't prep them right or what, but the paint is all crackily, and looks bad. I'm not sure if I can sand them down and repaint, or easier to just change them if they were cheap enough. But I can't even find them listed anywhere? On one thread someone said they thought the new grills have them built into it, and not separate pieces. Any thoughts from someone that has messed with them before? Thanks! Earl
vikingsandpintos is offline   Reply With Quote
Old 10-25-2016, 09:55 AM   #2
jjzepplin
jjzepplin's Avatar
Re: 67 grill inserts?
Subbed for info.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-25-2016, 10:19 AM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I haven't purchased them aftermarket, but the factory one's are riveted in. fairly easy to remove if you wanted to. there is good access if you wanted to sand blast them, I have done that a few times for some in rough shape.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-25-2016, 10:37 AM   #4
Blakeman350
Blakeman350's Avatar
This should help
http://www.lmctruck.com/icatalog/cb/...ille%20inserts
Blakeman350 is offline   Reply With Quote
Old 10-25-2016, 10:41 AM   #5
vikingsandpintos
Junior Member
I looked at the LMC link, other than the billet ones, it doesn't show the stock type that are open. It has the big grill assem, and the trim, but not the parts that rivet on? Unless I am missing something, which is entirely possible!!
Old 10-25-2016, 11:02 AM   #6
michael bustamante
michael bustamante's Avatar
i didnt see them either.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-25-2016, 11:15 AM   #7
DaHos
DaHos's Avatar
They are not sold individually but do come with the new 67-68 grills.
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 10-25-2016, 11:21 AM   #8
Oldblue68chevy
I drilled out the rivets on my grill to remove the inserts. That allowed me to sand blast and repaint them. I used some 10-32 stainless button head bolts to reinstall them. It worked well and they didn't interfere with the surround.
I also used two of the upper inserts on my grill and used some amber led strips for turn signals to slick it up a bit.
Oldblue68chevy is offline   Reply With Quote
Old 10-25-2016, 03:31 PM   #9
EARNHARDT#3
EARNHARDT#3's Avatar
What inserts are we taking about here?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 10-25-2016, 03:55 PM   #10
SS Tim
SS Tim's Avatar
GM called them "extensions".
SS Tim is offline   Reply With Quote
Old 10-25-2016, 04:36 PM   #11
Grumpy old man
Grumpy old man's Avatar
As far as I know no one reproduces the shelves . And I'm pretty sure the don't come on a reproduction grille .
Old 10-25-2016, 06:39 PM   #12
Elliot949
Elliot949's Avatar
Do you need both upper and lower?... I have a lower...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 10-25-2016, 09:44 PM   #13
EARNHARDT#3
I thought I've noticed something in there on some pictures I've seen. Mine are missing. Kind of strange since my truck was mostly untouched. Who knows...
Old 10-26-2016, 08:46 AM   #14
Tim Christian
Tim Christian's Avatar
No one sells them by themselves but they do come on the new Key Parts 67-68 Grill as DaHos said and he can help you with the complete grill.
Tim Christian is offline   Reply With Quote
Old 10-26-2016, 09:04 AM   #15
Willie Makeit
Willie Makeit's Avatar
I wonder if there is a chance to convince Key Parts to sell these pieces separately?
Willie Makeit is offline   Reply With Quote
Old 10-26-2016, 09:28 AM   #16
vikingsandpintos
Junior Member
Thanks for the replies.... As much aftermarket support as there is for these trucks, I'm kinda surprised these parts aren't offered! I am going to see if I can make mine look ok, and if I can't I will get with those that have extra's. Thanks! Earl
Old 10-26-2016, 09:39 AM   #17
jjzepplin
jjzepplin's Avatar
I just checked my grill and they are both there. It is off the truck right now if you need some pics.
Old 10-26-2016, 10:10 AM   #18
vikingsandpintos
Junior Member
Pics would be great if you have a chance! I would like to see what I am getting into before I start taking stuff apart. I prob won't get into it till mid-winter, the truck will be going into my garage in a couple of weeks, and have some other stuff we are doing to it first, but I am all for any info I can get. Thank you! Earl
Old 10-26-2016, 11:04 AM   #19
jjzepplin
jjzepplin's Avatar
Not sure if this is a 67 or 68 grill but the inserts should be the same.
Old 10-26-2016, 11:13 AM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
If the paint is just cracked, strip and repaint them. An hour with paint stripper and a wire wheel and you'll be done.
Yes, from the factory they are riveted, as others mentioned, just use small machine screws to reattach them.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-26-2016, 11:22 AM   #21
vikingsandpintos
Junior Member
Thank you... It looks and sounds like they are steel, I assumed they were plastic or fiberglass! I was wondering about the sandblast suggestions, but that makes more sense now... lol... I'll have to get mine all apart and see what I can do with them.
Old 10-26-2016, 11:26 AM   #22
67ChevyRedneck
Nope, metal, and pretty durable.
Jesse James
Project "On a Dime"
