Old 10-26-2016, 05:46 PM   #1
weq92f
weq92f's Avatar
A/C evap drain install -non-A/C cab
So, I've acquired my new 67 SWB Fleet side. The VAir system was installed about 5 years or so ago and was never used AFAIK. I'm assuming this really because the compressor had the wrong seal and would not hold vacuum. Not to mention, now that I fixed that, I have a new leak in my interior!
My problem now is that I need to make a drain hole somewhere for the evaporator condensate. VAir instructions say measure 1" down from the drain nipple on the Evaporator housing, drill a 3/8" hold in the firewall at that point and then put the hose through that with an elbow fitting.
What have you all done with your evap drain? Anybody know where the factory location would be for a factory A/C cab?
Thanks,
-weq
weq92f is offline   Reply With Quote
Old 10-26-2016, 06:48 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: A/C evap drain install -non-A/C cab
Factory AC cab doesn't have one! The evaporator is on the motor side in a factory setup. Just do as the directions say and all is fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
a/c, drain, evap, leak, vintage air
