Old 10-31-2016, 12:35 PM   #1
Bulldog88
My 72 has 14mm Wheel studs has anyone ever seen this?
So I replaced the front rotors on my 72 and find out that the lug nuts don't work anymore because it had 14mm 1.5 thread size studs, my new rotors have 1/2 20 standard that was weird to me anyone else seen this before
Bulldog88 is offline   Reply With Quote
Old 10-31-2016, 01:13 PM   #2
Orange Crate
Orange Crate's Avatar
Re: My 72 has 14mm Wheel studs has anyone ever seen this?
The Dorman catalogs are available here:
http://www.dormanproducts.com/Pages/...gs/dorman.aspx
Choose automotive hardware, scroll down to section 10 and match your old wheel studs with the correct P/N new stud. You can also remove the old studs and reuse them. I would recommend installing any stud with a press but it can be done without also.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 10-31-2016, 10:51 PM   #3
You are saying your truck has had 14mm studs and lug nuts up until you replaced the rotors/ if so, someone changed all the studs to 14mm at some point. Is your truck a K/10 or K/20? 14mm is closest to 9/16",which is what K/20s had.
Old 10-31-2016, 11:55 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
At some point the rotors were replaced, and came from a year where metric was used. I used to have an '82 Regal that had one rotor with metric fasteners, and the other was the same as the rear studs, with US threads.
~Steven
Simi Valley, CA
Old 11-01-2016, 10:04 AM   #5
Mike C
Mike C's Avatar
What rear axle is under the truck? I would guess somebody did a rear swap to get a more highway compatible gear ratio and then swapped rotors on the front so lugs would match.
Truck doesn't have the late model 8 lug aluminum wheels does it?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-01-2016, 11:35 AM   #6
Bulldog88
What's weird is that the rotors appear to be 72 because it had the Grove going thru the rotor, I think someone changed the studs, the rear end still has a 71 72 style rear end but uses 14mm lug nuts that's weird
