Anyone know about this wiper setup for our trucks ?
Just thought it was interesting , it says it fits/works on the 58 (which i have)
http://www.ebay.com/itm/161825807900...%3AMEBIDX%3AIT |
Re: Anyone know about this wiper setup for our trucks ?
Looks VERY "universal" and would require making it fit much like any other motor that didn't fit.
![]() Notice it says it's "compatible" with 852 vehicles! No kidding! ![]() Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Yea , i saw that , it just said that its the kit a lot of people use for hot rodding , customizing , etc , , so i was not sure if anyone had tried one , and tried to make it work (if its feasible) as a replacement for our older truck wiper systems , making it more updated/modern/less quirky
It just looked "promising" , and definitely less costly than some replacement units i have seen |
Hollister Road Co.
My understanding is they get noisy after a while, You may be happier with a Newport or RainGear system that's more specific to the truck your putting it in
Yea , the Raingear is out of my price range , the Newport is closer , but it says it wont replace a electric wiper system without converting the arms , etc , i need to check under the dash when the weather breaks ( the truck is outside under a tarp till i get my shop built , which is on hold till my broken wrist/arm heals up in another 6-12 months) and see if mine is the electric , or vacuum wiper , i am guessing its easy to tell the difference , i just remember the wipers being "quirky" , they either went slow , or really really fast depending on the speed you chose
Personally I love the vacuum wipers.
I rebuilt the one in my truck years ago driving it every day. My Rambler that I drive now every single day has the original vacuum wipers. I put a little oil into the vacuum inlet to soften up the flap and wham, works like a charm. I love how they work.Brian
rainX is your friend
![]() truk has electric wipers, though i have never used them and i drive truk a lot
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
I use Rain-X washer fluid in my 90 Toyota truck/daily driver , and still have a large need for the wipers any time it rains , especially when a 18 wheeler goes flying by on the 2 lane Highway i drive regularly (U.S.95) , you end up with a windshield full of muddy mist thats bad enough you can't see 10 ft ahead , its like that with and without the Rain-X (Washer Fluid) , i can almost half empty my Washer Fluid Reservoir going to town and back on a real rainy day (30 miles each way) , its that bad sometimes , gotta have good working wipers here
#9 | |
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
Got ya , I just figured Rain-x is Rain-x , but when a Semi blasts dirty muddy wetness at you , you still need good wipers , just sayin ..
how about if you just use the stock wiper posts and arms, get a wiper motor from something that is really common and cheap at the wreckers. then fab a bracket under the dash and connect the dots with a modified arm system. use the old arm system and modify the crank from the old motor to work on your new motor. that way the crank will be the same length so the length of travel for the wipers will be the same. can't be that tough, it's just steel, cut and weld the two cranks together so they end up the same length as the old crank was or custom fab a whole new crank. then it is a matter of mounting the motor in a position that will fit under the dash and allow the wipers to "park" at the correct spot on the window.if you are using a newer style steering column you can use the original wiper switch to make it all work and add in the washer pump as well.
another route to try is a wiper motor from heavy equipment, like a rubber tired backhoe or some sort of agricultural equipment like a farm tractor. just try to find a motor from something common so you won't have an issue down the road if you need a replacement. |
There are several posts where guys used the rear window wiper motor from a blazer on AD trucks. Not sure if it would work for task force, etc. A guy on YouTube has a channel called Mrhevyshevy and he used one on his 55 second series now that I think about it. It's not that complicated if you have some moderate fabrication skills. One guy here on the forum also made several kits and was selling them, but I cant remember the name.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.comBartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
Correct me if i am wrong , but isn't the TF wiper motor oscillating ? , i thought it went back and forth , not in a circle like most "modern" wipers motors , due to the configuration of where the the pivots are placed in the cowl vent ??
Motor spins in a circle, lever regulators at arm pivots convert to back and forth across the glass.
#15 |
To clarify my earlier post. The blazer rear window wiper motor oscillates. Not sure if this helps.
#16 | |
The above link has several options for AD wipers so go back to the beginning to check it all. My copy of the link takes you to page two to get you to post #27 and #28 for the guy that was making the kit. The date is 6 years ago so he may not be doing it anymore. Clay |
#17 |
Thanks ,,, that looks a bit too involved for what i want , , i might just have to look more into that Newport motor that dwcsr mentioned ...
#18 |
I would lean toward junkyard units rather than aftermarket. Three reasons.
One, price. For something you are going to have to fabricate anyway, why spend a ton of money? Two, Quality. Has anyone else noticed what utter junk most aftermarket parts are? I've never bought an after market part or kit that I didn't think was junk. Maybe I'm not spending enough... Three, easy replacement. WHEN your after market part fails, you won't be able to get another one as easily as you can an OEM application.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#19 | |
Hollister Road Co.
#20 |
Yea , but its a bit out of my price range/budget , i am on a pretty tight budget if i want this truck to be drivable anytime soon *last time it ran was 2005* , as it is i have a lot of work to do (as soon as my hand/wrist heals enough to actually build my shop so i can start working on it) , gathering the parts i will need is going to be the main priority for now while i am healing , i can't even hold a bottle of water with my hand right now , let alone a wrench *well i can use my right hand , but its not really coordinated , and some things you just need 2 functioning hands *
So i am focusing on finding the parts to get it road worthy (engine rebuild,brakes,brake lines, steering box/column,electrical components *like wipers that work better than what is in it now* , windshield , door rubber , patch panels for the bottom of the door itself *which is why i need door rubber* *passenger* , gas tank *either relocated or larger stock replacement*) , this is just to get it road worthy so i can start driving it in some comfort and safety , not pimp it out..... Anyway , i have to work within a reasonable budget to do what i need in a given amount of time....so if i go over on something , then it takes away from something else ... sucks , but its what i have to work with to accomplish my basic goals , i can eventually do more later , but the budget is controlling this part of the build for now ... |
#21 | |
#22 |
I agree with that 100%.... I will be adding the purpose built kit to mine.. no since in re-inventing the wheel.
#23 |
rainX washer fluid can't compare to the original rainX, the ineffectual washer fluid gives rainX a bad name
wipers have this hypnotic effect of making ogre's eye lids heavy, even i the daytime original rainX has no problem with passing or following semis
#24 |
that looks nothing like my original at all. mine goes in a circle also, not back and forth. I have a spare that works, but not sure I want to get rid of it. They are hard to find around here.
#25 |
I know that this is an old thread but read this if you are thinking about purchasing the universal wiper kit...
I purchased that wiper kit in Post 1 and wasted $120.00. That universal wiper kit will not work on our trucks. Its cable driven. It may work on a wider car body but our trucks are too narrow. The only way that I could mount the motor was near the oem mount area- This requires this cable system to snake around in S turns to pick up the connection to the wipers. The cable binds up. Motor came apart. I got the motor and linkage back up and running but realized it had to be mounted in a straight single line in order to work. I wasted a full day trying to make this work every which way I could think. Don't waste your money and time like I did on this kit.
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B]1965 fleetside Sold |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
