10-31-2016, 08:12 PM | #1 |
Active Member
327 Harmonic balancer
Rebuilding a 327 and noticed there is no bolt or threads in the crankshaft that holds the balancer in place. I check a 350 on an engine stand nearby and it has a 1 1/2 fine threaded bolt and a 1/4 inch washer on the crankshaft holding the balancer and pulleys in place. Is this supposed to be?
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
11-01-2016, 09:07 AM | #2 |
Re: 327 Harmonic balancer
Yes your 327 Harmonic balancer was pressed on, nothing unusual about it
11-01-2016, 11:18 AM | #3 |
Active Member
Thanks jrainman I have not worked on a 327 before and thought the missing bolt was odd. Very simple explanation.
11-01-2016, 02:28 PM | #4 |
Ive been driving my 64 impala SS for 10 years now with a press on one for the rebuild with no issues.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-01-2016, 02:29 PM | #5 |
If I remember correctly,the high performance engines got the bolt.
In 67,I believe all small blocks got it. My original 68,C-10 with 327 has the bolt in it. Mike. |
11-01-2016, 07:41 PM | #6 |
Active Member
Hmmm! The 327 engine I am working on is a 69 with a 68 date code. Then I check a 69 with a 307 and it has no bolt. All the 350 4 bolt blocks I checked have a bolt. Interesting.
11-01-2016, 09:38 PM | #7 |
As I recall, most of the small journal motors had press on balancers. They usually had short water pumps too. I think 67-68 were the cross over years where you could get either style.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
11-02-2016, 09:56 AM | #8 |
Yes small journal ( Steel crank ) got the pressed on , large journal (cast crank ) got bolted
