11-01-2016, 10:14 AM | #976 |
Re: 69 GMC "Ol' Blue"
Hey looky there, nice!
Brett 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
11-02-2016, 09:30 PM | #977 |
Like most of the original parts, the old one was destroyed and leaking. This one came with the engine when I bought it, so I thought what the hell
11-02-2016, 09:31 PM | #978 |
Thank you Brett! Maybe in another 10 years, I'll be as close as you are on yours
11-08-2016, 12:08 PM | #979 |
Find the time to get it running (perfect winter project) then send it out for paint this spring! All done, your welcome!
11-08-2016, 11:21 PM | #980 |
Haha, that sounds like a good plan. Devil is in the details though
11-24-2016, 11:35 AM | #981 |
Happy Thanksgiving all! I'm excited to report that I am slowly making some more progress! A friend of the family made me a bracket for my radiator, as well as my ECM! I'm excited to get it this weekend and get it mounted. I'm also going to check some mundane stuff off the list to get me closer to firing up! Boring stuff like plugs, wires, distributor and oil filter. I know it's not exciting, but it's on my startup checklist workbook so it should feel good to gain some forward momentum on the beast. Here's a pic that my buddy sent me of my ECM bracket that I will mount under the dash.
11-28-2016, 11:24 AM | #982 |
Nice, very profesh!
11-28-2016, 05:27 PM | #983 | |
69 K10 SWB Project Dream '69 2011 K2500 Silverado Beat to fit, Paint to match Dream '69 Build Thread |
11-30-2016, 10:47 PM | #984 | |
Thanks Brett! Yeah, I'm pretty happy with how it turned out. My buddy is quite the metal man
01-02-2017, 05:53 PM | #985 |
Got a few more little items done this weekend. Finished mounting the radiator, dropped in the distributor, and installed the serpentine belt. Small progress, but progress anyway
01-09-2017, 11:02 AM | #986 |
Good job, what’s next on the list? You are so close to hearing that exhaust!
01-09-2017, 11:15 AM | #987 |
Well, I'm down to some wiring, fluids, heater core, oil cooler (or plug both for now). I did get the plugs/plug wires, ecm mounted, and oil filter spun on. I think within the next couple of weeks, we'll be ready to crank her over!
01-09-2017, 02:33 PM | #988 |
Amazing how much "stuff" has to be hooked up to get to the point of a startup. I hope your startup goes well for you.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-24-2017, 10:58 AM | #989 |
01-24-2017, 04:13 PM | #990 |
6>8 Plugless........
Same here. It is looking nice. Keep up the great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-29-2017, 11:59 AM | #991 | |
01-29-2017, 02:28 PM | #992 |
Mike, just read through the build, Great looking truck man. As for the starter, do you have the original for the 465 bell housing or does the 94 block have provisions for a starter? I have an original if you need it could probably use a rebuild though.
Red |
01-29-2017, 02:40 PM | #993 |
Thank you Red! I appreciate the words of encouragement. The engine is out of a '91 Blazer and has the provisions for the block mounted starter, but the bellhousing is the original and won't quite fit the newer style. I know I could clearance the BH, but I think it would be easier to just stick the original one back in. I was able to call the parts store, and they still have my original starter, so I'm going to take the new one over and see if they'll let me swap the nose cones around. I'm sure they will no longer honor the warranty after that swap, but at this point I think it's all I can do. Thank you for the offer! I really appreciate that.
01-29-2017, 05:58 PM | #994 |
After running over to the parts store, they informed me that there was a starter change mid-year and they sold me the wrong one. They had one in stock, and we're in business! Small progress, but it's still progress! I'm going to finish up connecting the fuel pump wire today and probably call it a day.
01-29-2017, 08:50 PM | #995 |
It was actually a pretty productive weekend of getting small items checked off my list. The remaining items are:
After which, I should be able to fire this baby up!!! |
01-30-2017, 01:53 PM | #996 |
Good deal on not having to do surgery on the starter. That to-do list is starting to look pretty manageable!
01-31-2017, 11:15 AM | #997 |
Good progress Mike!
02-03-2017, 02:40 PM | #998 |
Nice luck on the starter..winning a bit at a time.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
02-03-2017, 11:47 PM | #999 | |
Thanks Brett! Not going as quick as yours, but I'm definitely making forward progress. Thanks Mudman! I'm here tonight trying to figure out what power steering lines I need. I have one of the lines that goes from the HB to the steering gear, but that's it. |
02-06-2017, 11:36 AM | #1000 |
Only small progress made. In trying to hook up the heater core, I realized that I needed a fitting to connect it to the intake manifold. Ordered that. Then, I picked up some power steering hoses for the HB setup. The ends are the o-ring style, so they will need to get cut off and replaced with the inverted flare style at the steering gear. You would think that there would be a local resource that would have the tube nuts I need for that...nope. Yet another speedbump. Only thing I was able to do was get the harness fed through the firewall, but hey, it's one more thing that needed to be done. :-)
