Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-02-2016, 05:51 PM   #51
prostreet1967
prostreet1967's Avatar
Re: pretty dissapointed. (track results)
my race
https://youtu.be/ZPqZeAaG55M
full race coverage
https://youtu.be/mTEQP51dFM8
prostreet1967 is offline   Reply With Quote
Old 11-03-2016, 08:38 AM   #52
Super73
Super73's Avatar
Where is this done?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-04-2016, 08:02 PM   #53
prostreet1967
streets of mexico
Old 11-07-2016, 03:14 PM   #54
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Hey super been a while . Big street scene here. I hurt my trans AGAIN!!! so its been hit or miss for me . But PRO street drop me a line if you heading to NS to run. I live up in keller so that is my local track . No prep was a blast .
GMR-PERFORMANCE is offline   Reply With Quote
Old 11-07-2016, 11:40 PM   #55
prostreet1967
will do, may be next Thursday for rice killer
Old 11-07-2016, 11:42 PM   #56
prostreet1967
took truck out 2 weeks ago never seen it from this angle but since having back half done it has never left alot of rubber down and hardly smokes tires. video shows bad Wheel hop.
https://youtu.be/wOXdk4hpVPQ
ladder bars, pointed down 5-6 degrees. slicks @10 lbs
Old 11-07-2016, 11:46 PM   #57
prostreet1967
on another note figured out issue with sloppy transbrake. video below of issue. would quit recording and trans would stick in first gear
https://youtu.be/VUR4zpvpwVQ
pic is after running new ground for relay and data link connector.
foot braking I can only build 2# sloppy transbrake can build 12#
Old 10-01-2017, 09:14 PM   #58
prostreet1967
truck is coming around. time for ARB.
https://youtu.be/LIdlnOalp9A
Old 10-03-2017, 09:02 AM   #59
hotrod 80
mini truck racer
hotrod 80's Avatar
I wouldn't mind doing a tailgate cash days.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-03-2017, 10:32 PM   #60
prostreet1967
lmk u know how we get down.
currently number 1 on dfwss truck list and number 3 on no trailer list. blew coupler off n semis that if I would have won I should have been number 1 on both. should be back at it soon. spun cam bearing on last engine.
Old 06-28-2018, 11:24 AM   #61
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Late to the conversation but ill try to help.
1.Start with fuel level. On the Demons they like fuel 3/4 way up sight glass adjust the air fuel screws 1-1/4 turns out. slowly bring them in to get the best idle quality 3/4-7/8 turn i bet. make sure jetting is stock, check power valve size against engine vacuum.
2. make sure front and rear discharge nozzles are squirting fuel
3. flow your fuel pump and check PSI 6.5-7 to make sure you don't have a clog, you will need to make sure you have correct fuel line size from pick up to regulator.
4.35-36* of timing is all you should need
5.check spark plug gap .035-.040 peding on compression.
6. ohm spark plug wires or replace with new
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
