Old 11-02-2016, 07:49 PM   #1
Mhussnatter
Ride Height question with measurements
I just got my 69 C10 back from the shop where I had a 4 wheel disc brake conversion done. I am running stock 15X8 ralley's with 235-70-15's on all corners. I went with the normal height spindles in the front (CPP 4 wheel disc brake conversion kit) and the previous owner did a lowering flip in the back. To me it looks like the truck is riding too high in the front. Measuring from the ground on up to the bottom of the wheel well I have 30 3/4 " in the front and 30 1/4" in the rear. Please post up pics of your trucks and what your ride heights (measurements) are in front and rear? Should I go with a lowering spring in the front or cut springs and if so how much etc. All advice welcome. THANKS and I will try and post pics of the truck as soon as I can get some up here.
Huss
Mhussnatter is offline   Reply With Quote
Old 11-02-2016, 09:14 PM   #2
Mhussnatter
Re: Ride Height question with measurements
http://www.dropbox.com/s/h3d0sovlbio...mage.jpeg?dl=0
Old 11-02-2016, 09:16 PM   #3
Mhussnatter
Old 11-03-2016, 07:47 AM   #4
Mhussnatter
Any advice or assistance on this issue would be greatly appreciated and also if someone could tell me how to embed pictures in my post that would be great as well. I look forward to posting more as I fix up my 69
Old 11-03-2016, 11:43 AM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=627506
That is a step by step instruction on posting pics.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-03-2016, 08:50 PM   #6
Overdriven
Lots of good pics and info about the drop and tire sizes being run here in this thread. Compare where the axle centerline on the body is in pics to your truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=471442
Drop spindles are always preferable to drop springs. Drop spindles maintain suspension travel and don't compress the shock while shorter drop or cut springs do. More travel equals better ride. Whichever way you go only you can figure out how much drop will look good to you. Have a look at the gap between the wheel opening and the tire, measure it, figure out how much closer you want that gap. Does your truck have stock height spindles? Stock springs? If something isn't stock then you may not get the drop your expecting.
It's a little hard to tell from the angle (wish camera was lower and more in the middle) but I'd be tempted to just go with taller rear tires for some rubber rake.
Overdriven is offline   Reply With Quote
Old 11-04-2016, 06:16 PM   #7
bolivier
Truck looks good. Cut 1/4 coil in the front if you want to drop it that 1/2" to match the rear. Not enough to affect ride if you just have stock springs and cpp spindles.
bolivier is offline   Reply With Quote
