Old 11-03-2016, 12:10 PM   #1
chuychevy82lwb
1991 electric suburban gauges into a square ls swap
So guys i wanted to see if any one could help me out on this . Long story short i have got a hold of 91 burban gauge cluster and i have the voltage to work the temp (with adapter on the passanger side head and electric sender) but o cant seem to get the speedo to work i repined it and ran a wire from the 4k output to the speedo but no luck . I thought it was the speedo that was bad so i found a guy parting out a 90 burban and took thoes gauges and still nothing . Am i missing something .
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 11-03-2016, 07:01 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: 1991 electric suburban gauges into a square ls swap
did you repin the cluster connector or plug it directly in? if so, you have to repin it to match your truck, super simple as the printed circuit is easy to read. The speedo is simply, ground, power and vss input. nothing else. If you have the connector pinned correctly, verified power and ground is good, verified vss output, you got a bad speedo. I have a spare one or 2 in the attic
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-03-2016, 07:07 PM   #3
chuychevy82lwb
I repined it but it cant be the gaugues i physically saw the speedo work b4 it was pulled
Old 11-03-2016, 09:57 PM   #4
87chevy.com
If you know it works, its narrowed down to the wiring or ecu. Double check the correctly pinned , power, ground and signal from the pcm. Then check the vss output sensor wires to pcm. If wiring is good pcm or pcm calibration somehow is bad
Clint
Old 11-03-2016, 10:26 PM   #5
chuychevy82lwb
How would i check the vss output ? Amd what pin would i need to asure has power to rule out iys a lack of power flowing through it
Old 11-04-2016, 05:43 AM   #6
LeesTruk
Check continuity from the VSS wires (Pin A ppl/wht, Pin B lt grn/blk) to the PCM connector C2 (green connector) Pin #'20 (lt.grn/blk), and Pin #21 (ppl/wht). The output wire to the speedometer is also from connector C2, pin #50 (grn/wht). Again, check continuity on this wire. If continuities are good, and terminal pins are firmly in place, then you can check VSS output by raising the rear of the truck, disconnect the VSS connecter, put your test leads on the two VSS pins, the meter on AC voltage and have someone put the truck in drive so that the rear wheels move. If you have an AC voltage reading, then the VSS is working. Or, you can just back probe the C2 connector at pins #20 and #21 for the voltage reading (probably safer). If that's good, then the PCM is most likely the culprit. Assuming, of course the connection at the speedo is good. The film circuit boards can sometimes be tricky
LeesTruk is offline   Reply With Quote
Old 11-04-2016, 06:37 AM   #7
LeesTruk
Had another thought after writing the previous post. If you have access to a scan tool, see if it has live data for a speedometer reading. That would tell you that your electronics part of the "equation" is working
Old 11-04-2016, 10:42 AM   #8
chuychevy82lwb
Ill def. Check it out thanks you so much by any chance would you know what pin on the connector (back of the speedo ) would need to get 12v
Old 11-05-2016, 05:01 AM   #9
LeesTruk
When you installed the Burb speedo., did you re-pin the cluster wire connector from your truck (what year, BTW?) to match that of the "90 Burb? Here's what the cluster wants to see;
Pin # Wire and original color
1= Hi Beam, Lt.Grn
2= Ground, Blk
3= Oil Press., Lt.Brn
4= 12V ign. Feed, Pnk/Blk
5= Low Volt Light, Dk. Brn
6= Not used
7= Not used
8= Coolant Temp., Torquise
9= Illumination, Lt. Gray
10= LH. Turn Sig., Lt. Blu
11= RH. Turn Sig., Dk. Blu
12= Empty
13= Seat Belt, Yel.
14= Fuel Sender, Pink
15= Brake, Lt. Brn/Wht
16= Serv.Eng.Soon, Drk. Brn/Wht
17= 12V Ign., Pnk/Blk
18= VSS from PCM, Lt. Blu/Blk
When I did my '80 LS swap, I used the '90 Burb cluster, and the only wires that did not have to be swapped were #'s 1, 4, and 13
Old 11-05-2016, 07:48 AM   #10
chuychevy82lwb
Ok sweet and yes i repined it and its a 82 silverado with a 91 suburban gauge cluster
