Wiper Delay from Twouvakind
Does anyone know how to get in touch with Twouvakind (Bill)? I'd like to see if he still makes the wiper delay boxes for our trucks but haven't heard back from him on multiple PMs. I am trying to get everything under my dash sorted out and then install my A/C. I searched his tag and see that his last post was on 10-15-16.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Re: Wiper Delay from Twouvakind
I hope you get a response. I am very interested in this delay too.
I hope twouvakind responds, as I like to utilize board people, but I searched delay switches and found this:
Revolution Electronics, part # 13009 Gives you three delays, plus your stock slow and fast Amazon has them If you get no response, I think I'm going to order one of these. |
#4 | |
I appreciate the feed back. I have looked at that delay unit you mentioned and I like Twouvakind's better as it has an infinite delay control knob. I hope Bill is still on the board here as he has helped a lot of people, not only with his delay box but he also sells NOS parts.
Old member
I have his kit in my 71 and it's great. Give him time and hopefully he will return your e mails. It took me several weeks to get him when I ordered mine also.
The link to mine. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=616490
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks for the link. How is the delay working these last two years?
#7 | |
Old member
![]() Quote:
I really like having the delay. I drive my truck and it has been a really nice mod. ![]()
I just heard from Twouvakind and yes, he will be putting together more delay boxes!
FWIW: I have one of the original designs, probably the second run, and it still works fine.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Dec 2011
Revolution Electronics, part # 13009, gotta love those crimp connectors and t taps. Thank you for the positive feedback all. I will churn out another 20 or so once I restock my terminals and terminal shells. By the look of the interest meter, these should sell quickly!
[quoteD=Orange Crate;7761566]I appreciate the feed back. I have looked at that delay unit you mentioned and I like Twouvakind's better as it has an infinite delay control knob. I hope Bill is still on the board here as he has helped a lot of people, not only with his delay box but he also sells NOS parts.[/quote] |
![]() Join Date: Jan 2012
Sign me up!
![]() Join Date: Mar 2012
subscribed and interested
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Nov 2011
Sign me up for one of those as well! PM me some time, I may be able to help with the terminals you need.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
Thanks very much to Twouvakind (Bill) he is a valued member here. Hey, how did I not end up being the first in line for the next delay box run??!!
![]() I'm next in line then.....
#15 |
I'll take one sign me up!
#16 |
![]() Join Date: Oct 2016
Pardon the newbie question, so you still use the regular knob on the upper right of the dash but as you turn clock wise is switches from stock slow and fast to a variable delay. In other words, all the way to the right is super slow intermittent?
72 White Cheyenne, The Ghost |
#17 |
Old member
The regular wiper knob works as it always has.
The bottom one will operate the delay. You don't have to touch the factory knob at all if you don't want to. ![]()
#18 |
Just an update, pictured are 10 control to delay module board harnesses. A slow but somewhat steady build. There will be more to come. I will do my best to sift through all the people in line already.
#19 |
That's good news ! I believe I'm in line !!
#20 |
p.m. me when they are ready.. thanks
#21 |
Being relatively new to the board, can I get more information about this? Connections, use of, etc.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#22 |
Sure, provides 3-30 seconds of wiper delay using a small box to mount and a potentiometer connected via harness to box. Pot needs a 5/16" hole to mount. Also out of the box are 4 wires, one to ground, one to fuse panel and two to the factory wiper switch and harness. If it a 67-72 my then you have an additional two wire harness in between the wiper switch and harness.
#23 |
Thanks again to twouvakind for putting these together (not to mention the engineering behind them too).
Bill, I sent a PM, thx.
#24 |
Still building, none in stock at this time. Keep an eye out in the 67-72 parts forum. I do post in 60-66 as well when I have them. Thanks to all who have stepped up, showed interest and plunked down cash to keep this project going.
#25 |
how much are these going for? I have not seen a price on them.
