Old 11-05-2016, 07:34 PM   #1
68c10Tyler
Need help with 4 link
I just purchased a rear end off Craigslist for my 68 c10, the rear end has a 4 link set up and I'd like to use it and get rid of the trailing arms set up. I need ideas and help to put a four link set up and what all needs to happen and any ideas are welcome. I wanting for it to be a sreet/strip set up. If there are any kits that would work I'd like to know what ones
68c10Tyler is offline   Reply With Quote
Old 11-06-2016, 06:59 AM   #2
andrewmp6
Re: Need help with 4 link
Does it have any kinda mount on the back side for a panhard bar ?
Old 11-06-2016, 10:15 AM   #3
68c10Tyler
I don't think it does. Where would it be located?
Old 11-07-2016, 06:25 AM   #4
andrewmp6
Would be on the back side of the axle.If it don't have that then its not a 4 link its a ladder bar set up.
Old 11-07-2016, 11:49 AM   #5
PGSigns
PGSigns's Avatar
Those are 4 link brackets. It would have had a diagonal link or a wishbone setup to keep it in the middle. You are going to need a setup like this to go in the back. It should be setup on a chassis jig to get it all in straight. Also before you go to far you may want to ensure that the housing and brackets are all straight.
Jimmy
https://www.cachassisworks.com/c-432...ame-clips.aspx
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-08-2016, 04:40 AM   #6
68c10Tyler
The guy I bought the rear end from said he ran a Comp engineering magnum 4 link. So I'd have to run a wish bone set up so the rear end won't move? And will let I have to back half my frame?
Old 11-08-2016, 06:46 AM   #7
bbbc10
Diggin The SquareLife
All u need to do is get or make 4 link bars to mount to the rear end an then make of buy brackets to mount the front of the 4 link bars to the frame then make or get a panhard bar that welds to the frame then welds to the axle so the rear end dont move from side to side.....im curious did u do any research before hand?
bbbc10 is offline   Reply With Quote
Old 11-08-2016, 08:27 AM   #8
PGSigns
PGSigns's Avatar
You are going to need to back half it to get it to do like it should. They take up a lot of room and need room to move. Here is a picture of the Comp rear frame with that four link installed. Gives you a good idea of what it looks like with the entire system and it shows the coil over mounting and the diagonal link installed. My suggestion is that you find a good chassis shop and get some help.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-08-2016, 08:34 AM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by pgsigns View Post
my suggestion is that you find a good chassis shop and get some help.
Jimmy
^^^ x2
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-08-2016, 12:01 PM   #10
68c10Tyler
I did a little research and could find what I was looking for. Could I use a different set up than doing a back half because I'm kind of on a budget. Could I notch the frame and still be able to run it or would I need a different kind of 4 link for that?
Old 11-08-2016, 01:51 PM   #11
bbbc10
Have u not researched other setups etc or did u jus buy this wthout out any info
Old 11-08-2016, 02:08 PM   #12
PGSigns
PGSigns's Avatar
You either need to go down the road correctly or not at all. If you don't do this as it needs to be done than you could be in worse shape than a stock setup. A four link setup wrong can be an evil ***** to drive under power. It looks like it has c-clip eliminators and disc brakes. You could look int swapping that stuff into your housing. Has it got a spool in it and what gear? How wide is it?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-08-2016, 02:51 PM   #13
68c10Tyler
It has a posi and 4.56 gears. Would I be easier to just swap out the rear ends and keep the trailing arms? And I've seen these trucks with 4 link and they used a step notch. So I'm curious if I could do it that way?
Old 11-08-2016, 08:52 PM   #14
tinydb84
tinydb84's Avatar
Maybe I am missing something but why not cut off the brackets and weld on a set of trailing arm perches?
David
Instagram: myfabguy
Old 11-09-2016, 03:05 AM   #15
andrewmp6
I guess he thought a 4 link would be easy and simple since the axle already has brackets on it.But like said a 4 link has to be set up right or else its a nightmare and its a lot of cutting and welding to get right.
Old 11-09-2016, 08:21 AM   #16
PGSigns
PGSigns's Avatar
The reason I asked about the width is that his stock rear is 62 3/8, the later ones are 63 3/4 and if they did the c-clip eliminators using a stock with axle its now 2" wider and the added thickness of the disc can ad another 1/2" over the thin drums. So this setup can be 3 1/2" wider than what is in the truck. That means new wheels. There is a huge difference between the street four links you see on bagged trucks that go to the outside of the frame and a race four link. He is stuck with the width of the housing and the width of the four link brackets. And before any work gets planned it is really important to make sure the housing and brackets are straight and that the axle tubes have not moved in the center section. I have seen the factory spot welds break in both dragrace and off road housings. Chris Alston's chassis works is in Sacremento. I would take a trip up and have a conversation with them about going to this fourlink. Putting your eyes on this stuff in the store I think will help more than we can do with post here.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-11-2016, 04:10 AM   #17
68c10Tyler
What would be a good set up with trailing arms to make it hook? It seems like I should just keep it that way since I don't have the money and time to do the 4 link set.
Old 11-11-2016, 04:54 AM   #18
andrewmp6
Have you looked at http://www.nolimitengineering.com/pr...tegory=6157532
Old 11-11-2016, 02:46 PM   #19
tinydb84
tinydb84's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=326863
David
Instagram: myfabguy
