#376 |
![]() Join Date: Jun 2014
Re: Installed FiTech EFI and Fuel Command Center
OOOHHHH let us know how you like it! I love the idea of modern fuel injection but maintaining that classic carburetor look
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
#377 |
Re: What did you do to your Blazer/Jimmy today?
Well, everything went well with a couple short test drives yesterday. Took it to work today and got stranded twice on the way home. They have not corrected their issue with the fuel command center overheating and boiling the fuel.I mounted it where the heater and fan motor used to be, which I feel should be far enough away from heat sources as you can get in the engine compartment. Called Fitech and talked to Bryce since I had time to kill on the side of the road. He said that location isn't good even though the literature that comes with it suggests this location. Just keep kickin' the can....
#378 |
Got some parts back from getting zinc coated. They turned out great! Thanks DeadheadNM for the lead. Had some extra parts plated as well. Will be posting some for sale soon: )
#379 |
'72 K5, known as 'the Fox.' |
#380 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Nice!! So worth it.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#381 |
![]() Join Date: Nov 2014
Took some stuff to my media blaster so I had him sand blast a set of Rallys for my CST. Matched the two like new Wild Country All Terrains. Two new tires, four Rally wheels and a coat of paint. Not bad for $300.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#382 |
Those should look real Nice with some new trim rings and center caps.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
#383 |
Drove it around town running errands and taking my wife out to lunch....
#384 |
Picked up a roll bar for the Jimmy!
#385 | |
I don't like running trim rings for a couple reasons. They scratch up my freshly painted rims; they seem to fall off from time to time and I think the rim looks larger without the trim rings so don't run them.
#386 |
Mounted the rear seat.
Finished the wiring for my twin fans on the radiator. |
#387 |
Added a new transfer case shifter ring. Biller aluminum, made by fellow member Mcbassin.
Not the best picture, and not cleaned up, but a very nice product! Thanks Mike |
#388 |
Sofa King Crazy!!
I finished making my faux boxed frame panels. They are to hide all the wires and lines. Did the whole frame, bead-rolled and dimple-die as well.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#389 | |
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#390 |
Yesterday I installed a seat belt on the drivers side. Then I bolted down the center console.
Today, I installed a new set of hood hinge springs. My Blazer had hinges but no springs. For twenty bucks and a half hour of work my hood opens and closes easily now. Plus, I learned a new trick on installing the springs that made the job really easy. |
#391 |
Got an update from my metal guy on my CST. Front cab support, inner rocker and floor repairs are done on the passenger side. "A" and "B" pillars are almost done and a final figment of the outer rocker is going on now.
#392 |
![]() Join Date: Jan 2016
New Coys today. Still waiting on the rears to ship.
#393 |
#394 |
Thanks dirish
#395 |
![]() Join Date: Jan 2001
I put it on vehicle dollies so I can move it around until it can move itself around.
#396 |
Those wheels look great. Really nice Blazer. Love the 67/68 front clip. That's what I want eventually. Wish at least one year of Blazers had been delivered with that look. I love them all, but that's the best look. IMO...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#397 |
Big Block
Put new gas tank on my 71 2 wheel drive Jimmy.. Aftermarket tank with short filler neck. That was a real treat. 5 hours later and a lot of cursing it's on and the gas gage works but bounces around while driving it. Why didn't they just use a stock filler neck? I know it can be used for other applications but it would be a lot easier to cut it to fit rather than being short and ending up hitting the top edge of the frame rail. What a pain. Finally got the frame rail modified enough to clear the neck.
#398 |
They had a sale at the local Truck shop in Orange. Wife and I blew our monthly budget today, LOL.
New front grill kit includes inner and outer grill and headlight trim. Rear bumper kit includes new rear bumper, and all the hardware, license plate mount and brackets. A bunch of new emblems for the fenders and glovebox and dash. Wife really wanted to fix up the center console I mounted recently so we got all new trim parts. Picked up a new set of front seat belts. Our '72 4x4 will be looking sharp soon. |
#399 |
Had a great day working on the Blazer. Installed the new rear bumper, lic plate and plate holder and plate light. I got lucky and the wire I hooked the lite up to was the right one and worked like a champ.
Then I installed new arm rests, and some trim parts around the center console. I also bought a bracket from one of the guys here in New York. It is the part that the front folding forward bucket locks into. Got it, painted it up and installed it and now the seat is nice and secure. It was nice of him to include the factory bolts too. The seat had no seat belts so I installed a set of lap belts too. |
#400 |
Small stuff....Painted the grill black (ordered new emblem), replaced blinker lenses and side markers. Then added tailgate band.
