'85 350 no fast idle?
Hello,
First off let me start by saying I have an '85 with a 350 and California emissions package ![]() Thanks! |
Re: '85 350 no fast idle?
Assuming it's a quadrajet with an electric choke, just richen the choke setting. Rotate the black cap ccw. There's three screws that hold it on. There's a high idle screw under the choke pull off pot. Hard to see but just needs a phillips to turn it.
Kicking it down depends on how rich it is and how quick it warms up. |
Thank you, I will attempt this tomorrow.
#4 | |
Take a pic!!
Is it screwed or riveted on? |
Okay I got the choke plate to close and cap adjusted correctly. Onto the fast idle issue:
I turn the truck on: Fast idle occurs. I blip the gas. Fast idle continues. I manually press down on the fast idle cam and it kicks it down a step or two. Suggestions? |
Turn the cap again to lean it down. It's a compromise. You gotta experiment to find that sweet spot. You mighta gone too rich.
It's all a juggling act!! I'm assuming this is an electric choke?? |
Yes it's an electric choke. So I backed out the fast idle screw a little and cleaned it up. I blip the throttle and it kicks down! I'm sure the neighbors have been tired of hearing that thing idling so high at 4am. Thanks for your help #99!
Fast idle and choke fixed! |
