Closed Thread
Old 11-08-2016, 03:50 PM   #4601
matthamby
Re: What did you do to your truck today? Chapter II
If Hillary can share secrets, so can he!
matthamby is offline
Old 11-09-2016, 10:21 AM   #4602
rsgt
rsgt's Avatar
Well this is actually what I did yesterday. I did some custom painting on my door.
rsgt is offline
Old 11-10-2016, 10:47 AM   #4603
74baggedbug
Installed the led dome light a forum member made for me.. it's really really bright
74baggedbug is offline
Old 11-10-2016, 12:28 PM   #4604
matthamby
i'm pretty upset about the dome light I put in a few months ago, it's already broke on one side where the plastic clips hold it in, so the other side will break before too long and it'll be hanging like the old one was!
who made it for you and how much? if they don't mind us knowing...
Old 11-10-2016, 08:46 PM   #4605
LongBox
Today, I removed the cowl cover on my 69. The Lisle wiper removal tool works like a champ, and I'd recommend it at the very low price. Actually, the hardest part about removing the cowl cover was figuring out the needlessly complex radio antenna mounting system, but once that was done, no problem.
Cleaned up thoroughly under the panel, lubed the wiper linkage, gave the cowl cover a good waxing, cleaned up and treated the rubber seal that goes between the cowl and the engine hood, then put everything back together.
The reason for doing this was to make sure that there was no accumulations of dead leaves, dirt, and other crud that would hold moisture and promote rusting. Feels good to know that all the metal under there is in really good shape (no rust at all), and that one more little job is done.
Next, vacuum bleeding the brake system, next sunny day.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline
Old 11-10-2016, 08:50 PM   #4606
LongBox
Rick
LongBox is offline
Old 11-10-2016, 10:54 PM   #4607
Metaldoc
Metaldoc's Avatar
I put leaf shields for rain gutters, bought them at Home depot
Metaldoc is offline
Old 11-10-2016, 11:15 PM   #4608
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Didn't do this today, but mine are buttoned up tighter than a drum.
"Spotted" in sheet. And then sealed with adhesive. Painted flat black..
I still get fresh air. Through the windows and wind wings..
Using Vintage air if I want to change the temp. Works for me.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 11-10-2016, 11:50 PM   #4609
LongBox
Great idea. Wish I'd thought of it about 8 hours ago
Rick
LongBox is offline
Old 11-11-2016, 02:52 AM   #4610
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Nothing, but tomorrow I remove the brakes from the cab and dive into the accelerator. Takes me a while, but this cab is nearly stripped.
Now if I can find someone to remove my windshield. At this rate I'll end up doing that too. I'd rather not. This is all new to me, and the windows have the stainless.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 11-11-2016, 09:01 AM   #4611
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
If you aren't saving the rubber gasket which I wouldn't want to reuse one after been taken out myself removing the window is very easy. Cut the gasket with a sharp razor knife and it will fall right out. Have some help to catch it though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 11-11-2016, 01:42 PM   #4612
71CHEVYSHORTBED402
I won't be saving the gasket. Maybe I'll five it a try. You recommend any special tools, like plunger cups?
http://www.autobodytoolmart.com/equa...FQuraQodlbsAiw
Tony
Old 11-11-2016, 06:16 PM   #4613
demian5
demian5's Avatar
New diff and brake booster for me this weekend. Going from a blown up 373 with posi to an open 308.
And no vacuum leak will allow me to adjust my carb properly.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline
Old 11-11-2016, 06:17 PM   #4614
demian5
demian5's Avatar
1986 C20 Scottsdale
Instagram: C10sofOC
demian5 is offline
Old 11-11-2016, 10:58 PM   #4615
Custom/20
Custom/20's Avatar
Received my bumper guards from brotherstrucks that were back ordered for a couple weeks. Had a slight hiccup while installing them because the bolts were not long enough but after getting the correct length bolts they bolted on no problem.
Custom/20 is offline
Old 11-12-2016, 07:07 PM   #4616
ohboy321
ohboy321's Avatar
Cleaned out a bay and put the truck inside before winter sets in. I bought it in June and it will never sleep outside again.
ohboy321 is offline
Old 11-12-2016, 08:17 PM   #4617
custom10nut
custom10nut's Avatar
Today I finally got my Map Lights wired and working. I aimed my bumper driving lights. I ordered a new Dash bezel, that should be here by Wednesday, so I'll be redoing my whole dash next weekend. Can't wait.
custom10nut is offline
Old 11-13-2016, 07:58 PM   #4618
66clow
66clow's Avatar
Painted my wheels gloss black, made a big difference. Had a dumb moment, went to move my truck and it wouldn't move forward or back. Thought oh no my transmission. Got underneath to check the linkage and was fine. Checked fluid fine. Burned my arm on the exhaust, ouch! Come to find out after putting the wheels back on I still had the rear jacket up.
66clow is offline
Old 11-13-2016, 08:27 PM   #4619
colgad
colgad's Avatar
Finally got the 6.0 I rebuilt into the 67 today. Also changed from Auto to manual. Still have wiring to do and the normal, but soon!
No more carburetor, turn the key and go even if it does sit for a week or two!
The 350 has a Thumpr cam and was a little to much for traffic so the 6.0 is a little milder. I went with a older A833/NP440 4speed overdrive that has almost the same ratio's as the 200R4 it replaces. The Vintage air compressor pulley has to be changed to the one I used for testing on the engine test stand. I used Captain Fab's clutch brackets with my HydroBoost and it worked great.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 11-13-2016, 11:55 PM   #4620
wpavlis
Jacked up the rear and got the fill plug loose on the differential. Hopefully I have time this week after work to change the fluid. Also finally got my interior heater box out so I can clean the last of the mouse nest out.
wpavlis is offline
Old 11-14-2016, 07:36 AM   #4621
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Have a helper and the suction cups are a good idea too!
Andy4639 is offline
Old 11-14-2016, 07:29 PM   #4622
matthamby
That sounds about right, we must be related!
Old 11-14-2016, 07:59 PM   #4623
trac209
Today I took it for one last drive and then put it in garage for winter. Latest time of year I've ever been able to drive it without snow.
trac209 is offline
Old 11-16-2016, 06:41 PM   #4624
66clow
66clow's Avatar
Finished the body work and rattle can fautina to the blue panels. Still need to take care of the white roof area. Also FedEx came with a few gems.
66clow is offline
Old 11-16-2016, 09:25 PM   #4625
Andy4639
Old member
Andy4639's Avatar
I got the new all aluminium radiator installed in the ramp truck today.
The radiator clamps don't fit perfect but they do tighten it down and hold it in place so I'm good with it for now. I just wanted to get it in before real cold weather got here. it has the proper water anti freeze mix now.
Andy4639 is offline
Closed Thread
